WTT XXR 535 wheels, 17x8.25 et 35 for XXR 535 17x7 - pair for pair
We have a set of four XXR 535 wheels in size 17x8.25, 35 offset. We know this is an ideal size for the rears, but a little wide for the fronts. Does anyone have a set of XXR 17x7 who would be interested in trading two for two so we'd both end up with a staggered set? Possibly someone buying a set of four interested in a straight trade for the rears? The wider rear fitment pair should cost a little more, so the lightly used condition should even things out.
We are located in Shelton, CT but make semi-regular trips to RI, Guilford, Stamford, Oxford, etc.
The wheels are in very good shape, no curb rash or other major marks. They came with our donor and look to be nearly new.
Is there gonna be fitment issues with et35 I was thinking of using a similar size that's only available in et35..what size tires are you planning to run Thx. Good luck
Yes, they will fit. They are the same wheels that Grassroots Motorsports have on their 818 (Their rears are actually 8x8.75). We are just worried about the fronts fitting due to the 8.25" width. Grassroots has 17x7 on the front. We haven't figured out tires yet.
https://grassrootsmotorsports.com/pr...ot-wheels-818/
