19
Hindsight
Here is the final rear shift linkage after cleaning it up and cutting off the bits I didn't need. Have the new custom length cables on it as well. They look a little different than others I have seen, but they work great and have nearly no slop. The length was perfect too. 79" on one and 81" on the other. Can't wait to test drive it and see what it feels like while the gears and synchros are turning. I got high-temp cable housings but also wrapped the cables in heat sleeving as well for added protection.
Here is the exhaust. I just need to add a bend or two and a short pipe dumping the exhaust out the bottom via hidden tip, and add a wide-band bung to the bellmouth. Hoping for go-kart this weekend.
Are you making shift linkage pieces? I don't need mounting brackets I just need the arm on the shaft and hardware, bell crank and the rod from the crank to the arm. I have the cable rod ends.
