Had a question about the ball joint installation, the instructions say to install spacer then the castle nut, torque and then install the cotter pin.
However when I install the castle nut on top of the spacer and try to torque the ball joint stud just spins?
Also if I could torque the castle nut the nut would be below the cotter pin hole in the stud...
Anyone else run it to this issue?
Suggestions
Michael
