I'm betting I could just use this for half the cost.
http://www.summitracing.com/parts/sum-220195b/overview/
Thanks- Chad
Owner: Colonel Red Racing
818R ICSCC SPM
Thanks- Chad
Best to stick with what Peterson has spec'd for this type system. I'm going to monitor with a $10 gauge on sale at Summit. If I ever see positive pressure I'll make changes.
http://www.summitracing.com/parts/sun-cp8213/overview/
818R ICSCC SPM
This is what I've done it's in place of my oil filler neck on Driver Valve cover. I also use a "mini" DS oil tank for a AOS vented back to the the main oil tank no problems: http://www.timeattackforums.com/foru...-dry-sump.html
Dave,
Thanks for the link. Nice work on saving $$$ for your system. Especially on the hand made dry sump pan! I like yours better than the ARE:
I noticed an "expert" insists that you can't run a two stage scavenge on a Subaru and get enough vacuum because the crankcase positive pressure will overcome it and the heads "must" have their own scavenge stages. <Again!>. I guess Cosworth Engineering never tested that theory, nor did the expert.
Has your regulator ever vented positive pressure? Do you have a vacuum/boost gauge connected to it?
I saw this Subaru powered Radical for sale at Radical USA cars for sale webpage. If you look close in the top pic you'll see the dry sump lines coming off the pump. They are angled forward which is the way the Cosworth pump is setup.
Cosworth pump setups:
Back to the Radical:
Only $65K for a used Radical....
818R ICSCC SPM
818R ICSCC SPM
