Thread: Making My Own Exhaust System
    Since my build is somewhat a one-off using a highly modified Mk4 frame and a Bruce C 289FIA body, there aren't any off the shelf exhaust systems I can use. SO I am building my own and using CSX 2430 as my source. CSX 2430 isn't an FIA and it uses a hybrid exhaust system. It has sidepipes similar to a 427 S/C. The differences are slight.
    I began my accumulating some parts:
    Merge collectors (Dynotech, P/N 783-21230)
    3" straight tubing (Summit Racing, P/N SUM-640030-1)
    Car Chemistry 3", 3 disc inserts (Car Chemistry, P/N 3DI03R)
    Coarse steel wool packing (Burns Stainless, P/N ??)
    90 deg 3" elbows (Patriot Performance, P/N H7062)
    1.625 mandrel bends (SPD, P/N 316325-16 and 316340-16)
    Header flanges with stubs (Hedman Hedders, P/N 11288)
    Here is a rough mockup of what they will look like once I have the car and can measure for the correct length
    Until the car gets here I can't weld the collector to the straight tube or mock up the primary pipes. But tonight I did weld the Car Chemistry Inserts wrapped in coarse steel wool into the collectors. Then filed the welds smooth
    Master Builder
    Long Island, NY
    How did you know how many disc's to use ?
    Kenny
    It's based on how quiet you want it. My last Roadster gave me headaches after long drives. I want this one to be quieter yet not rob too much hp
    So will the side pipes be slightly tucked under the body but still showing? Will it be like a lake pipe exit at the front of the rear wheel? I can't see that big pipe fitting under the body like a conventional exhaust. It looks like it's going to be a very clean looking system with few restricitions, though. Good luck, WEK.
    Here is CSX 2430 showing the sidepipes. Mine will be like this
    Welded the straight tube to the 90 deg turnout. Once the car arrives I can mock everything up and cut to length and trim the turnout
    Junior Member FFR7434's Avatar
    Jan 2012
    Houston, TX
    Beautiful work.
