Results 1 to 11 of 11
Thread: #7479 Build Thread
    Member josrodes's Avatar
    Medford MA
    Wink #7479 Build Thread
    I picked it up 4/2, talked to Dave Smith at the factory, really cool guy, toured the factory, great chatting to him. After that we loaded it and drove it home 75 miles. Wife was really happy and jumped in.
    It kept me busy so far, I figured it was time to post the first day pictures.
    I'm really enjoying it.
    Jose
    Medford MA
    Progress Update
    This is 15 days into the build.
    Footboxes are done, firewall done, passenger and driver side floor and sides all done, steering rack, steering shaft, pedals, flexible front brake lines done.
    So far this have been fun.
    Jose
    Medford MA
    Next steps
    I'm waiting for the tubular front lower control arms from FFR, the ball joins were back ordered when I picked up the kit, still waiting for it.
    In the main time I got everything ready to just drop it in as soon as that gets here.
    1) Mounted the brackets on the spindles(had to use the grinder on the spindles bc the bracket wouldn't fit, it was easy anyway)
    2) Got the Rear and front coil overs assembled
    3) Did the 3 link conversion on the rear
    4) Started working on the dash, need to figure out how I want to setup the different switches.
    Some pics.
    Jose
    Senior Member OttawaFFRer's Avatar
    Ottawa, Canada
    nice start!
    10 years after my roadster build....
    289 FIA (pickup 28/08/20 if covid permits)
    currently building a 289 and accumulating parts needed to finish a Canadian Kit.
    wow I've had mine for (2) TWO YEARS and you are already ahead of me (procrastinator extrodinare), congratulations man!!!!!
    Cowards are vile, vicious and vindictive in private, but innocent and charming in front of witnesses; no-one can, or wants to believe this individual has a vindictive nature - only the current target of the coward's aggression sees both sides.
    Stress filled occasions do not make heroes or cowards; they simply unveil them to the eyes of men .........................
    Fort Lauderdale Fl.
    great work!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Senior Member Gopher's Avatar
    McHenry, Illinois
    Picked up mine on the 26th of March and I start drywalling the wifes new kitchen tomorrow .I keep saying four more weeks and l get to start.I'm running out of room for kitchen material due to the pile of car parts.l just about have everything l need for the build.Like they say happy wife happy life and right now she can't be happier.
    Anniversary Special,Dart Aluminum 427, AFR 225 outlaw heads,Howard Cams,Hillborn stack injection,Liberty Gears prepedTKO600, Five Link, ISIS Wiring,8.98 @151 with no power adders Photo album HTTP://photobucket.com/anniversary-car
    Medford MA
    Engine is in!!!!
    Done since last post.
    Brakes lines
    Gas Lines
    Gas Filter
    Gas tank
    Body harness
    EFI Harness slimmed down.
    Rear 3 link
    Trunk rivets
    Here is the proof
    David, my step father helping out today.
    Needed a break
    All in
    Really enjoying all this.
    #7479, EFI, Tweecer RT, 3 Link, tubular, Konis.
    FFR6671 Fifty-Two's Avatar
    Thousand Oaks, CA
    Dang!!! Moving along quickly. Nice Job!
    - John
    Mk 3.1 - FFR6671 - "Trying" to recreate a Semi-Comp 427...
    427ci FE Big-Block / Pin-Drive IRS / TKO600 / Smiths Gauges / SC Dash / 15" Goodyear Billboards
    Fabrication (the fun stuff): 427 Throttle Pedal (SS) : AC Pedals on Wilwood Arms : CSX E-Brake Lever : CSX-Style Footbox Vents (SS) : CSX-Style Dash Support Tubes & Recessed Dash : CSX-Style F-Panels : Firewall Forward 4" : "Full" Rear Drop : Recessed Bulkhead & Exposed Rollbar ... hopefully the list continues!
    Now that is a engine hoist! You may not realize how lucky you are to have that!
    Medford MA
    Cool Some more pics.
    Thanks, I agree they don;t build things like in the 70s anymore, I'm very lucky to have access to a good hoist, my step father is the actual owner, the best part is that you can put it all apart and throw it in a pick up with almost no effort and yes it holds this engine and tranny easily without getting tipsy.
    I got some more stuff done today.
    -Bent the clutch and brake pedals to have more space in between them, they were too close for my taste.
    -Had to grind the top of the gas pedal it was hitting the clutch plastic thing on the pedal box.
    -Attached the alternator and power steering
    -fuel rail and injectors
    -started plugging EFI Harness into what I have already setup.
    -Needed to pick up a new belt, I had a 73" for the AC removal but didnt realize my donor came with under pulleys so I had no tension on the belt, picked up a 71.5" and it installed like a dream.
    I took Tuesday of at work so I should be able to get some more done. The front lower control arms should arrive on Monday so I will have some more things to play with this week.
    Goal is first start end of next weekend and go Kart the weekend after it, keeping fingers crossed.
    Some more pics from today.
