Results 1 to 3 of 3
Thread: 33 hotrod - what rear spring rate?
    [email protected]
    Nipomo, CA
    33 hotrod - what rear spring rate? or is it adjustment?
    using koni coil overs
    setting is 1 turn in
    car does not take road irregularities well "jouncy" in rear
    rear does not stick when pushed ... understeer
    245 45 18 tires all around
    front koni's are also 1 turn in
    any ideas?
    Charles Town, WV
    Changed the shocks to QA1. The Koni's were too stiff on their softest setting and need to be removed to adjust stiffness. 400 #/in. springs in front, 225/475 #/in. progressive springs in rear. Rides nice with shocks fairly soft, can always increase stiffness.
    Ditch the Konis. Dan Ruth can get you what will actually work.
