Likes Likes:  3
Page 35 of 37 FirstFirst ... 253334353637 LastLast
Results 1,361 to 1,400 of 1452
Thread: Andrew & Tamra's 818SR EM Autox Hybrid Destroked Long-Rod Build
  1. #1361
    Just for reference, with auto-x, we do have multiple starts in one day, with a pretty short drive between.
    Our hope, based on other autox'ers is that this battery will easily make it through the day, and that we can just disconnect it for the weeks between. If not, we have a pretty serious jump box & will swap out for a battery that can. Race cars not starting is no fun, when you need to be pulling up to the line.
    "bug" fired up very quickly on the lead acid, so hopefully the same will be true with this battery, so it shortens the cranking time & WH consumed, so there are more starts per charge. We will just limit the AWIC pump time without the car running.
    -Andrew
  2. #1362
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Sneak preview....
    and....
    No looking back now! Go big or go home!
    Tamra
    First autocross 3/29/15
  3. #1363
    Apr 2015
    Andover, MA
    wow!
  4. #1364
    Those are huge! Nice work.
  5. #1365
    Puyallup, WA
    I take it the flares that you purchased didnt work out too well?
    More pics of the flares please
  6. #1366
    Apr 2014
    Shelton, CT
    No, not at all unfortunately. Since the 818 already has flares built in to the body, when you cut the body away for tire clearance, you are essentially removing the built in flare and replacing it with the Ebay flare which isn't any wider. On a Miata, sure, but not the 818.
    We will post photos of the entire process when we are done, don't worry! Still lots of work left to get it to a finished product.
    Tamra
  7. #1367
    Puyallup, WA
    Thanks for the reply. There is definitely a lot more to deal with on the 818, as far as angles and shapes, than you would find on a typical production car. As you may know, ill be doing a full wide body as well and still have not finalized what it would look like exactly. So many ways of approaching it. The goal being that the final product looks intentional and cohesive.
    Nice work tho. Keep up the progress.
  8. #1368
    Senior Member Oppenheimer's Avatar
    Milford, CT
    ...I had to hit with a more powerful battery charger, the little battery tender charger wouldn't kick off the charging.
    A Battery Tender won't engage charging unless it sees a minimum amount of voltage present (this is part of how it doesn't spark if you touch the leads together when its plugged in). If you have a very dead battery, you can trick the Tender to start Tending if you just put some juice across it. A 9V battery will do. Use a bare 9V battery harness. Just hookup Tender to dead batt, then put the leads of the harness across the Tender terminals for a sec, until Tender light shows charging has started (observe polarity!) Then you can remove the 9V battery. You could also use another charger that doesn't have any sensing tech built in to get a Tender going.
    I connect alligator leads to the 9V harness, and I also use it to keep radio presets and ECU programming intact if I need to remove battery from DD. Connect the 9V leads to cars batt terminals, remove terminals from car batt, remove car batt. The 9V is enough to keep electronics going, as they typically run off 5v. Obviously this only works a short time, and don't open doors (interior lights!) or do anything that will require real 12V juice, as the 9V won't have enough oomph.
  9. #1369
    Flares look very cool.
  10. #1370
    Fenton MI
    I've been following this build for a long time, one of my favorites!
  11. #1371
    Way to GO Tamra!!!!
    http://sololive.scca.com/L1.html
  12. #1372
    Apr 2014
    Shelton, CT
    Thanks Bob!
    Tamra
  13. #1373
    south-central CT
    Looking at the scores... Aren't you faster than the majority of cars and comparable men's classes? #12 overall? Awesome.
    Pax Index Overall
    1 SS 78 Patrick Salerno 2011 Porsche 911 GT3 58.696
    2 CSP 199 Billy Davis 1999 Mazda Miata 58.985
    3 SSR 57 Grant Reeve 2003 Chevrolet Corvette Z06 59.089
    4 KM 33 Larry MacLeod Honda Tonykart 59.218
    5 SSR 89 Matthew Braun 2004 Chevrolet Corvette Z06 59.280
    6 AS 27 Mark Daddio 2007 Chevrolet Corvette Z06 59.303
    7 STS 69 Benjamin Wagstaff 1991 Mazda Miata 59.454
    8 SS 178 Brian Conners 2011 Porsche 911 GT3 59.503
    9 CSP 98 Neal Tovsen 1990 Mazda Miata 59.529
    10 B2 157 Scott Giles 1985 Honda CRX Si 59.538
    11 STX 192 David Marcus 2013 Scion* FR-S 59.622
    12 L1 99 Tamra Hunt 1999 Mazda Miata 59.639
  14. #1374
    Apr 2014
    Shelton, CT
    Pax Index Overall
    Yep Thanks Glyn
    Tamra
  15. #1375
    Tamra or Andrew - I believe you mentioned an S2000 car cover fit your 818 well. Which brand and type are you using and is it fully waterproof? I'm looking for one that I can take with the car when I go to shows to keep the cabin covered if it starts to rain.
    Thanks in advance!
  16. #1376
    Apr 2014
    Shelton, CT
    Thanks in advance!
    It's an OEM S2000 one, and I don't *think* it's waterproof. It does bead up a little so I would call it water resistant.
    Also, I'm selling my S2000 in case anyone is looking http://newhaven.craigslist.org/cto/5660475950.html
    Tamra
  17. #1377
    Thanks for the info.
    Selling the S2000 huh.... what's next?
  18. #1378
    Apr 2014
    Shelton, CT
    I don't know yet! Keeping the RX8 and making it DSP trim for autocross though, so I need a new winter car ;p
    Tamra
  19. #1379
    Cool cool - Get a Ford Focus RS
  20. #1380
    Fender progress has been... slow and intermittent, but it is coming along. We blew out the bearing on the random orbital from shaping all the foam, replacement going in tomorrow, but need to do some tire mounting.
    Also, last week I got a toy (yes, me! not Tamra yet)
    It's on trials as a 4 wheeled motorcycle replacement, which is somewhat safer.
    I have commuted in it twice now, and It's pretty fun!
    It's a locost 7 (book chassis) with a 2003 R1 engine & the incorporated sequential transmission. Whee!
    -Andrew
  21. #1381
    You guys have no lack of toys! I admire the passion.
  22. #1382
    That is nice!
    And I won't post my comment about the "toy" and "Tamra".
  23. #1383
    Senior Member AZPete's Avatar
    Hey, Andrew and Tamra, with no posts for 6 weeks I hope you are okay. Have you shelved your 818 in favor of the new toy?
  24. #1384
    Hey Pete,
    I believe they are at autocross nationals in Lincoln Nebraska for the next week.
    I hope she reports her results.
  25. #1385
    Apr 2015
    Andover, MA
    How go the flares!? Have you had the chance to make any progress? How's the Locost? I have the original Ron Champion plans book and always thought I would build one.....until the 818 showed up!
    -Ben
  26. #1386
    Hi Guys,
    Sorry for the disappearance!
    We built Tamra's RX8 for DSP, and it is lots of fun!
    We did go out to Solo Nats for a week and a half, also fun! Tamra won CSPL in a different CSP car than her normal, following a switch due to the normal car breaking.
    My locost7 has been a little fussy (starter issues), so I've been trying to get it back on the road.
    Bug the 818 is partially flared, but other things have been taking priority from it.
    -Andrew
  27. #1387
    Too many toys, not enough time Good to hear things are going well for the both of you. We miss your updates
  28. #1388
    Apr 2015
    Andover, MA
    Tamra looks so calm at the wheel....no death grip, just a casual embrace of the wheel! Telling I think. Nice job!
    -Ben
  29. #1389
    OK, so tonight was actually quite productive.
    My 7 has had issues starting (cranking, really) consistently, so I rebuilt the starter, installed it, and it was worse than ever. It turns out that there is an alignment required for the permanent magnets in the case. I pulled it, clocked it properly, tested (good!) installed, and it now cranks enthusiastically.
    Just a little FYI for anyone rebuilding a motorsports starter.
    Back to FFR things, I also went ahead and did the smelly messsy fiberglass thing again!
    The passenger flare had been nearly shaped for a while, with some bondo sitting on it for a final block sanding pass. I dove in and got that worked through, quite happy with the final contour consistency.
    The really rewarding part came next: Gel coat!
    It's fantastic to see the fender in white after so much time of yellow & pink. I'll have to give this a light sand and another coat later, but it will cure overnight.
    Definitely felt like a milestone though, to have color on the flare.
    We still need to trim the inside of the wheel arch, so don't mind the wavy line there.
    -Andrew
  30. #1390
    Edmonton, Alberta
    Looks great! Building flares from scrap intimates me too much, I think I'd pull my hair out trying to get it even.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  31. #1391
    Sounds about right
    We're past the "get it even" point, and more to the "get it smooth" and make it real points.
    -Andrew
  32. #1392
    Wow, I want that!
  33. #1393
    Last night I fiberglassed the driver side fender with another 2 layers and then painted on another layer of gelcoat on the passenger side.
    Tonight I did two rounds of bondo on the driver side, and a bit of block sanding on the passenger side.
    Things are definitely starting to come together with the solid hours I've been able to put in. Once the fenders reach a close-enough point, I want to get the car back on wheels and roll it outside to get a look at it from more than 2' away!
    -Andrew
  34. #1394
    Apr 2015
    Andover, MA
    Looks good. I agree on seeing it from more than 2'!
  35. #1395
    Apr 2014
    Shelton, CT
    I know it's been a long time coming with race season keeping us busy.... but here you go. First 818 to my knowledge with flares. Currently pictured with 315's on 18x11's out back (25 offset). Required moving the suspension inboard and the body outward (wanted to keep the car as narrow as possible).
    Tamra
  36. #1396
    Apr 2015
    Andover, MA
    Well, are you pleased with the flares? I think they look pretty good!
  37. #1397
    Edmonton, Alberta
    Looking good! Definitely need to post a rear strait on shot.
    818 SRX - #91
    Arrived 01/02/2014
  38. #1398
    very nice
  39. #1399
    Apr 2014
    Shelton, CT
    Thanks guys, we are very pleased. Still some cosmetic work to do. Trim the inner edge, clean up some gel coat spots. obviously finish the wrap job. But, they're functional!
    Here are a few more photos:
    Tamra
  40. #1400
    Nice work! Good to see you two are still at it.
