Page 4 of 4 FirstFirst ... 234
Results 121 to 140 of 140
Thread: MR2 Shifter
  1. #121
    Mechie3's Avatar
    Indianapolis
    I used 7'. I go back, around the heads, and into the bell crank. I tried 6' but they were too short. 6.5' would probably work well but I got off the shelf zero backlash cables (which aren't really 100% zero backlash).
    Zero Decibel Motorsports
    Check out my new website!
  2. #122
    Jun 2015
    cool, thanks. Need to get some on the way soon, just need to start fabing the shifter stuff at the back, just like yours, but ours is pull into first-second gate (RSX race shifter)
  3. #123
    Freeport, ME
    I used 7' to go under the ebrake, over the FFR fuel tank, through a rubber grommet on my rear firewall, over the engine block but under the manifold to the trans shaft and bell crank... Mine bow up a couple inches from perfect length. I used the clamp type cables, much easier to do the mounts, only need two tapped holes into the plate, both ends http://www.boatersland.com/telccx43307.html
    Dan
  4. #124
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Where is everyone getting their custom-length cables from? I was going to use "Custom Control Cables" but for what I wanted, the cost came out to $280 for the pair which is about $100 more than I expected.
    Edit - N/M ended up talking with customcables.com in California and picking up a set from them for closer to what I was expecting: $178.
  5. #125
    Mechie3's Avatar
    Indianapolis
    Seastar solutions. I can look up part numbers later.
  6. #126
    Dec 2013
    Any body willing to share their dimensions or CAD dwg?
  7. #127
    Senior Member JAubin's Avatar
    Goffstown, NH
    Meant to X-Post this from my Build Thread:
    I'm running the MR2 with a linkage that was designed for 914s running Subaru motors/trans. Hacked up the shifter so it sits angled, front supported by repurposed rear sway brackets, so it sits higher and the console fits over it, but the cables exit below the top surface of the tunnel.
    Attachment 44593 Attachment 44595
    I used the Midwest Control Cables customer option, and it was $80 for (2) 7' cables with bulkhead connectors on both ends. The swaged/crimped connections leave a bit to be desired, and there is a bit more stiction than in the FFR supplied cables, but with the nearly straight run (under intake manifold) and short length the feel is still far better than the stock setup. Photo shows the difference between the swaged connection on the FFR (TOP) and the crimped of the Midwest (BOTTOM)
    --Joe
    818S #234 V7 EJ207 Spec-C (VF34) Build Thread
  8. #128
    Bowling Green, KY
  9. #129
    Mechie3's Avatar
    Indianapolis
    Bump from the dead. Got two emails about my MR2 implementation. I heavily modified my shifter though, so it's not quite apples to apples.
    I'm using these cables:
    http://www.boatersland.com/telccx43008.html
    The 7' were about 1" too short, but they worked well for Bill (his shifter is in a slightly different spot). The 7' cables were purchased elsewhere (forget where) and had a 5 week lead time.
    Bulkhead mount on the rear, clamp mount on the front. I believe they can be used with these strap clamps from McMaster, P/N 3125K12
  10. #130
    I also used 7' cables routed directly over the top of the engine. I didn't like how the 8' had the bend around the ez30. With the six's intake and exhaust it made more sense to go over then around. P.S. I still have the 8' for sale...
  11. #131
    Mechie3's Avatar
    Indianapolis
    I have a spare broken 8' cable. I just shipped it to a customer along with some parts. The cable works, just has a very notchy spot. He's going to use it for a test fit. Once he is done, it's up for grabs. I didn't charge him for it, just asked that he pass it on to the next person. Use it to test fit, measure for cables length so you can determine if 7' or 8' works best without buying both.
  12. #132
    East Hartford, Ct.
    Does anybody know where this shifter comes from?
    Jack
  13. #133
    Mechie3's Avatar
    Indianapolis
    It's another version of the K tuned shifter. Maybe the one that FFR sells.
  14. #134
    Senior Member DSR-3's Avatar
    San Jose, CA
    Quote Originally Posted by JB91710 View Post
    Factory Five
  15. #135
    East Hartford, Ct.
    Thanks, I did find it at FF.
  16. #136
    Harley818's Avatar
    Vancouver BC
    I bought my cables from Control Cables. Bulkhead mount connection. 90 inches was perfect for me. I routed through the firewall right above the suspension attachment point behind the gas tank. $75 ea. Part no. 173LTT-2-90RS HP Inner.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
  17. #137
    Sgt.Gator's Avatar
    Bend, Oregon
    Thread from the dead revival....the MR2 shifters have jumped on eBay. Including shipping, they are at least $75 and some are $150!
    Owner: Colonel Red Racing
    818R ICSCC SPM
  18. #138
    San Diego Ca 92106
    whoa, glad I got mine from the local pick your part for $15. for $150 I'd spend the extra and either buy the FFR one and do the "Hobby Racer" mod to have the cables go to the rear or the K-Tuned shifter.
  19. #139
    shifter
    i have one i will sell you 50.00 plus shipping
  20. #140
    Sgt.Gator's Avatar
    Bend, Oregon
    Thanks. I made an offer on eBay for one at a significantly lower price with free shipping and it was accepted. I'm sure other sellers would take offers too, these things can't be in that big of a demand other than 818 builders.
    818R ICSCC SPM
