Coyote battery power routing
I am wiring my car using the Ron Francis harness info in the manual and the Coyote wiring in the coyote addendum to the manual. Everything makes sense so far except I can't see from the instruction how to make sure the alternator output gets to the battery. If anyone out there who has installed Coyote and can help me out I would really appreciate it. Basically the alternator feeds the Ron Francis harness and therefor the dash and the front and rear harnesses. The battery connects directly to the solenoid on the starter and then jumpers back to the engine harness. I can't see where the two systems (Ron Francis and Ford supplied engine harness) intersect to connect the alternator to the battery. The instructions are very unclear on this. I could simply run a jumper between the battery and the connections on the Ron Francis harness but I hate to do something that is not in the book. Any ideas?
