Sedan seat belt hack: tilt sensor delete
No matter how I fiddled with them, I couldn't get my sedan donor seat belt reels oriented so the tilt sensors wouldn't lock up. So I removed the sensors. Now the belts work great. The lock up feature due to sudden jerks on the belt is unchanged.
I took the driver's side reel off the car to delete the sensor, but I did it on the passenger side with the reel still attached.
To open the the reel, pop the three plastic pins that secure the transparent cover
The cover should pop off, I pried it gently with a flat head screw driver. Don't turn it over or the gears will fall out. They're easy enough to drop back in though.
The tilt sensor is the orange part in this pic, although it's green on the 818 passenger side (formerly WRX driver side) belt
It easily slips out.
Make sure the gear is in the right position . . .
. . . before you replace the cover.
Test the belt a few times to make sure everything is replaced properly, then pop the plastic pins back in and you're done. Now the belt will work with the reel in any orientation
