Thread: Differential Question
    Oct 2014
    We just finished installing the rear axle and we are concerned we did something wrong as the pinion points right at the fat round cross bar of the frame. THis seems wrong as the pinion wont have a straight line access to the transmission. Did we do something wrong? I have attached two pictures. Any help or guidance on this would be great!!! Thanks so much.
    Stuart K
    Fresno, CA
    Are you using the 3-link rear suspension?
    Blue Oval Scribe Mustang Man's Avatar
    Lakeland, FL
    Um, are you just letting the rear hang by the coilovers? Put jack stands under the axle and let the chassis "sit" on the suspension instead of letting it all hang. That will move the rear up several inches and into the normal "ride height/driving" location...
    HTH...
    Mark
    Modified Mustangs & Fords Project Snake Charmer
    FFR5310 Mk 3 Roadster
    Tungsten Gray/Silver Stripes
    Tech Support Manager, FFR Tony Zullo's Avatar
    Hi guys Tony@ffr looks like the axle needs to be on jack stands then you can use the upper link to adjust the pinion angle..
    Oct 2014
    Yes, we are.
    Oct 2014
    Excellent, thank you to Mark and Tony for the help!! Happy Thanksgiving
    Stuart
