SUPERFORMANCE COBRA FOR SALE (Canada)
SPF 2058 was one of the last Superformance cars accepted into Canada and therefore it is one of a very limited number (45?) available in Canada.
This Cobra exemplifies the legendary build quality of Superformance Cobras and has been kept in exceptional condition.
This is a one owner car that has been extremely well cared for. It has only been driven on optimal weather days and never exposed to rain or wet conditions. It has never been tracked or driven under extreme conditions. Only one driver! It has been stored onsite in a heated and protected garage since new. There are currently just over 10,000 easy miles on the odometer, all original components with no evidence of wear. There have been no accidents and no repaints. All required maintenance and necessary upgrades have been carried out and logged appropriately. It has been very reliable. Ready to drive.
SPF 2058 Superformance MKIII (Canadian Car)
One owner, one driver, registered and licenced since 2005
Purchased from Macro in Toronto, Canada
Order date September 2004
Delivery date February 2005
SUSPENSION/BRAKES/STEERING
Independent front and rear suspension
Front and rear adjustable coil over shocks
Wilwood high-performance disc brakes on all four corners
POWERTRAIN
Roush 402R crate engine (additional Specs available)
TKO 600, 5 speed transmission
8.8 rear differential, 3.73 gears
FEATURES
complete Smiths Instruments gauge package (with 'correct' reverse-winding speedometer)
hardwood-rimmed steering wheel like new
dropped footbox on driver and passenger side (for additional knee/leg room)
Soft top with side screens
Tonneau cover
ROLLING STOCK
1 set of PS Engineering 17" Halibrand knock off wheels
Michelin pilot sport 275 40ZR 17 front / 335 35ZR 17 rear (currently on the car)
1 set of SPF supplied Halibrand-style 15"/5-bolt true knockoff wheels (Excellent condition)
OPTIONS
Emblems: front and rear Cobra badges, Superformance logo steering wheel hub insert, Superformance badge on the trunk
'correct' Powered by Ford 427 side badges
Dual Roll bars polished SS (stainless steel)
Full bumpers (polished Stainless Steel)
4 point harness for both driver and passenger
Oil cooler (functional)
Silver ceramic coated side pipes and headers
Locking Glove box
Mounted Chrome fire extinguisher
Battery shut off switch
LED bulbs installed in tail lights
MSD 6AL rev limiter and coil
MSD Distributor
Removable Radiator protective screen
Removable oil cooler screen
Chip guard across the front and also on front of rear wheel well
Heater hose shut off valves added
4) MAINTENANCE
full documentation of all maintenance done to the car
Regular cleaning including the undercarriage and engine compartment
Upgraded rear suspension upper mounts as per SUPERFORMANCE bulletin
5) ALSO INCLUDES:
SPF Factory owners manual
Car specific manual (special order) from SCOF member
Complete electrical diagram created by SPF owner
Dyno pull data on existing setup
Original set of 15" SPF Halibrand wheels (like new)
Spare windshield (ordered as backup, never used)
Spare Fireflyperformance.com Polished Stainless Steel side pipes (never used, 3,000 value)
Spare set of SPF pin drive adapters (ordered for a Factory Five build but never used)
Spare set of SPF spinners (left and right), Never used
Spare set of SPF drive pins, never used
Spare engine mounts ordered as upgrade but never installed
Spare Remflex header to side pipe gaskets
Many photos available.
Car located in Ontario.
Additional information available upon request.
Serious inquiries only please.
$88,000.00 CDN
519-636-1440
