0
0
Anyone put their fuel pump/filter behind the waterfall?
I am thinking about putting in a subwoofer box through the back wall and under the gas tank..right where I was going to put the electric fuel fuel pump for the Quick fuel EFI system I am about to install. I could put the fuel pump and filter behind the waterfall but might worry about the noise..although I can use mass loaded vinyl and foam to cut that down.
Anyone mount their fuel pump behind the waterfall?
I mounted mine in the center above the driveshaft.
I mounted one there. I found it to be very noisy
Did you insulate the firewall at all?
Tech Support Manager, FFR
Yes i did and it was way to loud !! and thats with the waterfall insulated, so i moved it under the fuel tank.
Ah..that sux. Guess I need to rethink my subwoofer box.
