Hi all
I'm new to owning a FFR and have some questions as to what will work on my car. I've read as much as I could find on the subject in the forums and from what I understand is I will need to drill holes in the upper frame rear shock box to accept the coilover . Mine does not have the predrilled holes some of you lucky ones do . I read it's a bear to do with body on and then I found a post that said you could use the lower donor brkt with the stud in the upper location . That got me thinking and looking into the fox body aftermarket and sure enough both URP and Kenny Brown make kits to adapt rear coilovers into the stock locations
http://www.uprproducts.com/mustang-r...eavy-duty.html
79-04 Mustang Rear Coil Over Mounting Kit
http://store.kennybrown.com/product/...tang-and-cobra
Or even these for a GM
http://www.spohn.net/shop/1978-1987-...Carlo-etc.html
Does anyone see any problems using a kit like this with a mk1 or anyone used something similar ? ....This would make it so much easier .
I already have new upper and lower tubular control arms so I figured might as well do the coilovers . Any help would be greatly appreciated
