0
0
Pictures or it didnt happen 1/2
I think this was the end of day one
Fuel pump and filter location
This is how i mounted them, they are SOLID as a rock, the filters are bolted together and then held in place by the solid AN fittings. I was a little worried at first by putting the weight on them like this but you can use the filters as a handle and hang off this thing, its solid.
Regulator mounting location, i cut a piece of steel, it will be welded in soon. (I have since replaced some of these AN fittings to change the routing.
It was the first really nice day of the year so i brought out the RV batteries and went out to un-winterize the Winnebago.
This is the grease i used on the ball joints
Cont....
