Likes Likes:  3
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 401 to 440 of 477
Thread: JJ's 818s Build
  1. #401
    Sep 2014
    Dallas, TX
    Man that's great info!
    So far I believe just acetone will do the trick, after the search I did. Of course doing more will not kill anyone and you'll more than certain of the positive effects.
    I thought sanding would remove that damn wax! I hope it's removeable after sanding, with chemicals... I have quite some spots already sanded due to gel coat fixes.
    Did you need to use 3M Primer 94 on tight edges and curves?
    I did not use primer, I don't think it's necessary on the external surface. I thought it would be best used on the body filler. So I did a peel test and when removing vinyl that had been applied over body filler and set for over a day the wrap was very hard to remove and you could even see that it has lifted a very thin layer of the filler material. What I am most concerned about is the adhesion to the back surface of the panel. I did a lot less work on the back side, lightly sanded to 80 grit and spray painted with undercoating. I don't think my wrap is going to stick very long to this surface so I'm planning on adding plastic edge strips and/or the primer to the back side. If someone has a better idea I'd like to know about it.
    818S Chassis #288 2.5L 323hp
    joshuajach.com
  2. #402
    Quote Originally Posted by TouchStone View Post
    Well 3M 94 Primer is mostly used on sharp edges, not sure people use it for a full surface and body panels primer. It helps the wrap keeping its sharp turnaround like on hood edges. Then it would probably do a good job to hold the wrap in the inside surface of the panels. I didn't think about that but now you mention it, I think I'll get a pint of that primer and use it on the inside at least. I believe it would help on some edges of the nose insert, louvers' cut-outs and maybe the bottom outwards of the front fenders (new nose style). Just for the inside panels I think it's worth trying.
    Tna again!
  3. #403
    San Diego Ca 92106
    Cleaning wax and other contaminants off the body is nessasary before doing any sanding, otherwise those contaminants will be ground into the surface making it harder to get out.
    http://thefactoryfiveforum.com/archi...hp/t-7602.html
  4. #404
    That vinyl is looking great! I wish I could get the hang of it. Everything I have tried in the past ended in vinyl disaster lol. Keep of the good work its looking amazing
  5. #405
    Great job!!
  6. #406
    Sep 2014
    Dallas, TX
    Wrapped the hood tonight. Unfortunately I made a mistake right at the end. Lesson learned is to not rush at the end and to not stretch the material too much. I may be able to leave it as is since I have other plans for that area. I have it temporarily patched in the final picture.
    joshuajach.com
  7. #407
    Really looking nice! And it's your 1st wrap!
    Was the hood easier than any other panels so far (apart from doors)?
  8. #408
    San Diego Ca 92106
    Looks great, it'll look good in the sun.
  9. #409
    Sep 2014
    Dallas, TX
    The hood was about as difficult as the front fenders except for the air outlet area. I'm worried about the radiator heat causing the inside corners of the hood to peel off since I stretched the film quite a bit. I think I'm going to cut out the vinyl in those corners so I can apply new material without stretch.
    joshuajach.com
  10. #410
    Surprising the hood was that difficult.
    Maybe you can protect the vinyl with goild foil applied on top? Might prevent heat from doing anything on the inside corners.
  11. #411
    Mechie3's Avatar
    Nice! Liking the blue.
    Zero Decibel Motorsports
  12. #412
    Senior Member dallas_'s Avatar
    Dallas, TX
    Dang, that's really cool. Looking good!
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
  13. #413
    Sep 2014
    Dallas, TX
    Made some more progress
    joshuajach.com
  14. #414
    nkw8181's Avatar
    Dallas, TX
    sweet!!! looking good
    Nolan
  15. #415
    Really like the black you put around the humps. Very nice little touch to make a good difference!
  16. #416
    Sep 2014
    Dallas, TX
    I made a short tutorial on applying vinyl wrap inlays on the 818.
    818 Vinyl Wrap Inlay
    joshuajach.com
  17. #417
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Very nice work Josh, I bet Nolan is jealous.
  18. #418
    I totally forgot about these very recessed areas! I guess I need that wired tape.
  19. #419
    nkw8181's Avatar
    Dallas, TX
    Just a bit Wayne
    Nolan
  20. #420
    Sep 2014
    Dallas, TX
    I just ordered my 3rd roll of it.
    joshuajach.com
  21. #421
    You bought rolls of how long?
  22. #422
    Sep 2014
    Dallas, TX
    50 meter rolls. FYI I did the carbon fiber stripes with part of the first roll awhile ago.
    joshuajach.com
  23. #423
    Sep 2014
    Dallas, TX
    I've been done with the vinyl wrap for several weeks now but I haven't reassembled the panels yet as I made a last minute decision to swap out the transmission. I'm having a new gear stack built by "ZF design" with gear ratios 3.166, 1.882, 1.296, .972 and ,738 w/ FD 3.7 and Torsen LSD. I got pictures from them during the build.
    joshuajach.com
  24. #424
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Very nice! Are those gears stronger than stock?
  25. #425
    Sep 2014
    Dallas, TX
    Yes, but only a little.
    joshuajach.com
  26. #426
    As the transmission normally sits at a different angle than when in a Subaru and these are different gears, are they providing an oil level recommendation?
  27. #427
    Sep 2014
    Dallas, TX
    Quote Originally Posted by UnhipPopano View Post
    It's the same 5mt case so I plan to use the same amount as before.
    joshuajach.com
  28. #428
    I was wondering where you were at with the wrapping... Still need a big overview picture, though.
    You changed gears for what reason? I believe it's not strength, it is for better tuned ratios?
  29. #429
    Sep 2014
    Dallas, TX
    I haven't even seen it all together myself. The previous transmission had several bad syncros.
    joshuajach.com
  30. #430
    Sep 2014
    Dallas, TX
    Now time to drive!
    joshuajach.com
  31. #431
    Very NICE Josh.
  32. #432
    Dallas, TX
    Wow, that looks FANTASTIC!
  33. #433
    San Diego Ca 92106
    That color combo looks great! The racing stripes are a nice touch.
  34. #434
    Mechie3's Avatar
    The stripes on the front are fantastic!
  35. #435
    Bowling Green, KY
    The car looks great and love the color combo. Enjoy the ride, I am sure you and the car will get a ton of attention.
  36. #436
    Senior Member AZPete's Avatar
    Beautiful. I really like how your stripe incorporates both the hood vents and the engine cover humps.
  37. #437
    Super nice, man. Attention to detail, amazing.
  38. #438
    very nice finish!
  39. #439
    Hindsight's Avatar
    Atlanta
    Looks very nice! Clean!
  40. #440
    I knew you'd make it with the wrap! The result is just perfect! Enjoy the ride, you are really privileged to have a running legal 818!
