Likes Likes:  3
Page 2 of 12 FirstFirst 1234 ... LastLast
Results 41 to 80 of 477
Thread: JJ's 818s Build
    Quote Originally Posted by TouchStone View Post
    I want to send in my fuel injectors to be ultasonic cleaned, and flow tested. Can anyone recommend a place?
    This place can do it: http://www.deatschwerks.com/services...ector-services
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    The engine looks great!
    Tamra
    First autocross 3/29/15
    Harley818's Avatar
    Vancouver BC
    Dont forget to do Waynes coolant mod into the upper coolant casting before you go any further. It will be much easier before you install the engine, although a few of us have done it.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    Sep 2014
    Dallas, TX
    What mod is this?
    818S Chassis #288 2.5L 323hp
    joshuajach.com
    Frankfort, IL
    What mod is this?
    See post #8 in the attached.
    http://thefactoryfiveforum.com/showt...7s+coolant+mod
    Alternatively you can get a VW elbow which has a barb off of it to run back to the degas tank. (Goldwing did this and I copied)
    Sep 2014
    Dallas, TX
    Harley/Billjr
    Ill definatly be adding that port to help fill the coolant. Thanks for pointing it out.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Sent out my injectors to "deatschwerks", should have them back in a week or two. I like that they send out detailed test results.
    I wrapped my donor exhaust manifold and Grimmspeed up-pipe with DEI Titanium Exhaust Wrap. I'm not sure if this will actually improve performance, I mainly did it for the look. I'm not super happy with the job I did, but my excuse is that the 3 part OEM exhaust design does not make for an ideal wrap.
    joshuajach.com
    Member tebriel's Avatar
    WI
    Quote Originally Posted by rtz View Post
    I used to use racetronix.com back in the day with my turbo saturns.
    The main reason for wrapping the exhaust is to keep the heat out of the engine bay. I used SS hose clamps every so far to keep it tight.
    San Diego Ca 92106
    image.jpgHas any one have any experience with this tool?
    http://clamptool.com/pages/how2.html
    Now back to your regularly scheduled thread.
    Sep 2014
    Dallas, TX
    Painted tranny plate.
    joshuajach.com
    San Diego Ca 92106
    That is soooo nice, the talent and imagination on this forum is outstanding!
    Sep 2014
    Dallas, TX
    Went to harbor freight to buy some automobile wheel dollys, however they were on sale and sold out. So instead I built two rollable support bridges out of carpet dollys (inspired by another member). Total cost was around $60 half what I was gonna pay.
    The frame fits just bearly sideway in my garage which means I can turn the car around to drop the engine in.
    Now my daily driver will fit in the garage as well.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Engine Drop
    Someone made me jealous that they dropped their engine in. So of course I had to do the same.
    I decided to drop in the engine separate from the tranny since many people have complained about the difficulty of getting the engine in the 818. Plus the two were already seperated. Once the engine is in you need to add temporary support to keep it from tilting foward. I used a couple 2x4's, that can be seen in the picture, braced against the steering wheel pump and alternator brackets. (If you know a better way tell me)
    It took me two days to get the tranny in (due to inexperience). I had not aligned the clutch disk with the flywheel bearing. I used an assortment of sockets to fake the alignment tool and eyeballed it. Worked like a charm, very happy thats done .
    joshuajach.com
    Apr 2014
    Shelton, CT
    Congrats on getting the engine in!
    I'm jealous of your garage.
    Tamra
    Nice work!
    nkw8181's Avatar
    Dallas, TX
    Lookin good!
    Nolan
    DFW, Texas
    Looking really good. I'm in the Dallas area too. Just getting the donor torn apart and the parts all cleaned and painted. Should only be a month before I get my kit in. Let me know if you need any help. Would be glad to.
    nkw8181's Avatar
    Dallas, TX
    Sounds like there's three of us now in dallas!
    Nolan
    Sep 2014
    Dallas, TX
    Awesome! Now its a crowd.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Replaced my engine mounts with STI mounts. They look like they are just replacement parts but the rubber used is supposed to be stiffer and higher quality. They are also half the price of cusco mounts.
    Now I officially have the engine in.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Fuel Injector came back from deatschwerks. All 4 are consistent which is good enough for me.
    joshuajach.com
    Leesburg, VA
    I also picked up the stiffer STI (group-n) mounts but I noticed their steel mounting plates didn't include the integrated heat shields like the stock wrx plates. I ended up swapping the steel plates to retain the heat shields with the stiffer mounts.
    Sep 2014
    Dallas, TX
    I noticed that when I was swapping them out but I didn't think it mattered much.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Made a temporary table out of the shipping crate my engine shipped in. I'm going to be using it to layout and route wires for my chassis harness. The tape on the table is an initial layout plan for the front and rear or the car. Still need to measure the cabin for wiring.
    joshuajach.com
    Sep 2014
    Dallas, TX
    A messy table, will most likely get much messier.
    joshuajach.com
    Touchstone,
    Take a look at my thread,
    It might help you out. Let me know if you have questions.
    http://thefactoryfiveforum.com/showt...l=1#post146406
    Sep 2014
    Dallas, TX
    Woot, I've got one working headlight. Actually both would work if plugged in. This was mainly a test to make sure the relays are working as I expect them to.
    joshuajach.com
    Harley818's Avatar
    Vancouver BC
    Good call on the group N mounts.... from what I hear, the stock ones allow too much movement.
    i got the type N for engine and tranny. They are waaaay stiffer.
    I can relate to the wiring.... it will get way more messy!
    I did something similar, but laid the plywood on top of the rollbar and the front of the car..... right at work height and helped space it out right.
    I used the stock wiring, and just cut out and spliced in where necessary. All works now.
    See post #92, 94, etc
    http://thefactoryfiveforum.com/showt...y-s-818S/page3
    Harley
    Sep 2014
    Dallas, TX
    Got my front brake rotors in. The first paint job I did on the calipers is already noticeably flaking (bad paint job or surface prep?). So I think I'm going to repaint my calipers and probably change the color while I'm at it.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Finished wiring for the front lights and radiator fans. I'm happy with how it looks after the wire sheath is in place.
    joshuajach.com
    Have you considered putting a connector in the front section of the harness so you can take the nose off with removing all of the individual light plugs and pulling all of the zip ties?
    Sep 2014
    Dallas, TX
    Quote Originally Posted by Jaime View Post
    I hadn't considered ever taking the nose off. There is only 8 connectors in the front and I'll be using removable plastic clips instead of zip ties to hold the wires. So it shouldn't be too hard if the need arises.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Time for a quick rant about Subaru's wiring harness.
    Who came up with the idea to do this to wires? That black stuff reminds me of Silly Putty but much stickier and certainly not silly more like ridiculous ... "Ridiculous Putty"
    I dont know why they couldn't just do something easy and clean.
    joshuajach.com
    Sep 2014
    Dallas, TX
    More wires
    You can never have too many wires.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Testing my ECU with a code scanner and amp meter to make sure things are receiving power and communicating. The ECU reported a bunch of engine errors, I cant imagine why.
    I didn't have a car battery laying around so I grabbed the 12V battery from my cordless drill which works fine since I'm not planning on cranking the engine with it. Standalone the ECU uses uses about 3/4 to 1 amp of power.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Example of a bad solder connection I found off of my donor harness. Since I needed this connector for the wastegate I had to salvage what I could from it.
    Before:
    After:
    As reference this is what a good solder connection should look like. I am very confident that in a pull test the wire would break before the solder connection breaks.
    joshuajach.com
    Looks good. Are you using a soldering pencil or a mini torch?
    Sep 2014
    Dallas, TX
    I use a Hakko 936 solder iron I bought from sparkfun years ago https://www.sparkfun.com/products/retired/9672. An excellent tool with temperature control.
    joshuajach.com
    Sep 2014
    Dallas, TX
    Mostly done with the harness now, here's some in progress pictures:
    All the wires are laid out and needs a few more connectors from the donor.
    Soldered the main engine connectors to the harness, I used dual lined heat shrink to add support and waterproofing to the solder joint. The black connector has 6 unused wires which were used for the TGV valves and sensors. Would have de-pinned the connector but it would have left openings and defeated the water proofing.
    Installed wire wrap
    joshuajach.com
