So after getting the side panels mounted and rear taillight/bumper mounted, I was play around with the decking (2 pieces). The forward most deck is a pain to put on and get off as it curves around the roll cage bars, this will not work well at the track, the rear most part of the deck, there is no way that I can use hinges there, so that will have to be totally removable.
I was thinking that the forward most piece will have to be cut to allow easy removal, that is the curved piece around the roll cage bar will have to be mounted to fender and somewhere around the roll cage down tube is to cut the deck and add some lip to it.
I will most likely slot the rear most deck for the wing as I don't want to have to keep taking wing off (too expensive to have something happen to it) so I can pull the rear mist deck off. This will also be pined/latched. This brings up another point, as I'm not sure I trust mounting the pins/latches to just the fiberglass.
Thoughts ?
Also my intercooler is right up against the forward most deck, so no need for a support brace here
