Results 1 to 2 of 2
Thread: Fuse box mounting
    Lansdale
    Fuse box mounting
    I'm looking for some Ideas (pictures) to securely mount the 2 fuse boxes, Mine both ended up together under (what will be) the dash. I just successfully started the car for the first time and need to secure things for the first Go-Cart run!!
    here is what I did
    here is how I mounted my 'inside' fuse box under the dash. It is towards the passenger side :
    Bracket looking down from over dash:
    Bracket looking up from under dash:
    Installed bottom view:
    Installed top view:
    The fuse box is hidden by the dash (looking at it from passenger seat level):
    hope this helps!
