I have the following cables that came with my complete kit.
14690 3559
The caliper end has a slot and it looks like a washer and c clip should be on that end. Cant find anything in the parts that match up.
14690 3559
Baghdad Bob
I have attached a few photos from the build school. I don not believe there is a c-clip (refer to photo)
E Brake Cable.jpgE Brake Cable at Caliper.jpgE Brake Cable at handle end.jpg
15th Anniversary Edition
Mk4 - 18 month build (4 hrs every Sat), received Aug 2011, titled & registered May 2013, final in paint Nov 2013 - Ferrari blue
FRPP Crate Coyote 5.0, tko600, Moser 3 link, manual steering & 13" brakes, upgraded coil overs
koolmat then dynamat then carpet in cockpit - very solid, no engine heat transfer to cockpit and no road noise
When I built mine (same set up) That part just snugs into the brake caliper once you pull tight on the cable and then it stays in there by friction.
-Jeff
