0
0
Which drivesahft to order?
Can anyone tell me if the supplied 33 hot rod Driveshaft(part #33042) for Coyote / T56 (Tremec magnum) is long enough with a 4-link rear positioned back approximately 1 inch? Sorry if this is a redundant question but I haven't found an answer in the forums. I'm in the pre-order stage so I have nothing to measure and hope to avoid as much return and re-order as possible.
Thanks in advance for any help...
- You may not post replies
- You may not edit your posts
Forum Rules
