I got a newer kit and it came with the updated fuel tank and firewall. The instructions are telling me to mount the fuse panel behind the firewall just above the fuel tank. well, the firewall is flush against the metal tubing under the roll bars and there is only about 2 inches of space between the top of the fuel tank and the horizontal part of the firewall. Is there a revision in the manual addressing this, or has anyone figured out how to mount the box with the new tank and firewall? I am using the stock harness. I have searched the forum but everything I found is working with the old fuel tank. I'm basically stuck and cant go any farther on the build until I address this, any help is appreciated. thanks
