I'm an ex SCCA racer thinking about building his first hot rod. I'm torn between the '33 hot rod and the MK4 Roadster. Any comments would be appreciated
Welcome to the forum. They both are great builds, it just depends on what you want. The roadster will turn a lot of heads just from its shape while the 33 will turn heads more for the quality you put into it.
Doug
Built FFR5196 MKII in 2003, 427w
Building FFR0058HR, Edlebrock 347-AOD
That's a tough choice. I am drawn to both. Of course, the roadster is one of if not the iconic top of the heap for muscle cars. The early thirties hot rod is what started hot rodding. If you want more possibilities such as regular roadster, chopped wind shield, and hardtop then FFR makes it easy to create a swatch project. I thought about it but the hot rod project had not come very far when I was thinking of the build. Now there are all kinds of opportunities and unique builds. It's hard to beat the beauty of the roadster though. I still go out to the garage and just look at it sometimes. Maybe you will have to build both. Just choose which one first. If I was going to show the car, I would definitely do the 33 hot rod as it will show better, IMO. Examples are the differential can be seen easily (like a jag rear or quick change), the engine bay has so many options like with or without curtains or no hood at all. Yeah, it's a tough one to answer but how can you lose? I love my roadster. It fits me like a glove and I have never driven anything that was as much fun!
Good luck making your decision.
WEK.
San Antonio TX?
