Page 3 of 3 FirstFirst 123
Results 81 to 87 of 87
Thread: 818R front suspension adjustment?
    818 Junkie... bstuke's Avatar
    Atlanta, GA
    Getting Better! The 818R has potential, but won't ever make it in EM in national competition. And unfortunately I have a nationally competitive EM car her in ATL. I was within 3 seconds and that is a personal best. I ended up 9th raw time out of 130.
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Which event did you go to this weekend? Any videos?
    Tamra
    First autocross 3/29/15
    Atlanta, GA
    As you already know EM pax stinks, so here are raw times for Solo Atlanta points 6.
    DNF video...
    PS. No LSD so the car gets squirrely very quickly..
    818R For Sale!
    818R Sale Thread
    Bowling Green, KY
    Philly,
    I wouldn't be surprised if your Track spring set up and AutoX set up is different just because of how the car is loaded and transfers weight. Also the Aero on the track will have a bigger effect due to the higher speeds.
    It is fun watching the directions you all have taken, along with what Chad has done on the track.
    Apr 2014
    Shelton, CT
    Bstuke, were you not off course in that run? Definitely looked like you got sideways a bit! 3 seconds off of the yellow jeep is pretty good, considering your car doesn't have aero yet, you mentioned no lsd, I believe your hp output is pretty low (under 250 whp, right?).
    The jeep you are up against weighs 1750lbs with a driver, and is making 400whp/wtq, with very experienced drivers behind the wheel. That's a tough car to compare against!
    Tamra
    Atlanta, GA
    Yes it was a DNF. 230HP. I uploaded the wrong one! LSD getting installed in the next few weeks. The Jeep is EM as well so I have no choice. Minehart and Kiesel are even faster..
    818R For Sale!
    818R Sale Thread
  7. #87
    Atlanta, GA
    Here is my forth run, which was pretty good but didn't count...
    818R For Sale!
    818R Sale Thread
