Jim wanted me to link this video to illustrate the potential of the truck engine series. I believe we are the only two with L33 (5.3L)and LQ9 (6.0L)
powerplants?
The acceleration is tough to gauge in this video, but this is the first car that has put me back in the seat throughout the entire range of two gears.
Normally once second gear hits, you get the initial kick and the sense of the car picking up speed.
With the power to weight ratio of his setup, the force continued to press me into the seat until the clutch was pressed. This would indicate a
high RPM peak in the torque curve.
I'm sure many of you can relate having driven your GTM's, but this was the first time experiencing a completed car at higher speeds.
Thanks for the ride, and letting me test drive your G-Machine!
