Results 1 to 20 of 20
Thread: Whitby Motorcars Tonneau Dual Roll Bar
    Jul 2014
    MA
    Does anyone have one? I was curious about quality of the cover and for a close up pic of the fasteners.
    Raleigh NC, OIB NC
    Fasteners are standard "lift the dot" units that you would find on any English roadster.
    Kevin
    MKIV #8234
    Senior Member DaleG's Avatar
    Mar 2013
    Kevin, does the cover come with the "dots" already installed, or did you have to use the tool to install them in the fabric? Did you use the screw-in type for the body, or bolt-through type?
    Quote Originally Posted by DaleG View Post
    These fasteners are used in marine application too. I was a sailmaker for many years so I know them well. If you are using the screw in type be careful when removing the top. They can hang up causing extra pull on the fastener and the fabric (if you always release them straight up- no problem). You can actually damage the fabric around the female part if not careful. I never used the screw in type on fiberglass since a lot of customers were not that careful about how they removed their covers on the boats. I just watched the Whitbey instructions for the roadster soft top. I've been thinking about getting one. Same type and location for top and tonneau. Whitbey rents the tool for this process if you need it.
    WEK.
    Raleigh NC, OIB NC
    Hi Dale,
    The cover comes without the dots being installed. The studs are bolt on. I made an impulse buy on the cover when I saw one installed while I was there approving the final spray outs for the paint. I had Whitby do the install. Looks & feels like the covers on my Morgan's & Triumph's of the dark distant past. Good big zipper down the middle to ride with one side up in cold weather. They use Velcro to fit around the roll bar legs. A bit pricy put it does its job.
    Kevin
    MKIV #8234
    mcwho's Avatar
    DeBary - Florida
    I just Got the dual Roll Bar Tonneau from Whitbys, there are two type of lift the dot posts, I has a provision for a washer and nut and the other looks like a wood or machine screw tapered thread.
    Any Suggestions
    Baghdad Bob
    Raleigh NC, OIB NC
    With the body on you might not be able to get behind some of the panels to mount the washer & bolts. Might need the other type for those locations. I use mine during the winter to keep the heat in, no pulled studs so far.
    Lift the dot means exactly that, lift at the dot on the fastener to apply the least amount of pressure to the studs.
    Kevin
    MKIV #8234
    mcwho's Avatar
    DeBary - Florida
    I should be ok with the install, the panel behind the seats is removable and I made the dashboard removable as well. That just leaves the doors for the other kind of studs. I had several sports cars with these as in Fiat 124, sunbeam alpine and tiger.
    attached a pic of the two stud types for other viewers.
    Baghdad Bob
    Raleigh NC, OIB NC
    FWIW I only have one stud on the door & know all the rest are bolted.
    You can see the stud pattern here. This is a Whitby install, had it done when the car was painted. As mentioned it was an impulse buy when I saw it on another car at the shop.
    The stud at the front of the door is on the door. The one at the back is on the body.
    Kevin
    MKIV #8234
    Member ChasNMe's Avatar
    Sep 2018
    Charleston, SC
    can we see a pic with the cover off, please . . .
    Raleigh NC, OIB NC
    Quote Originally Posted by ChasNMe View Post
    Not sure what you want to see?
    Kevin
    MKIV #8234
    Sep 2018
    Charleston, SC
    thanks Kevin. I wanted to see how noticeable the studs were without the top on. and how the Velcro looked around the roll bars . . . studs aren't as noticeable as I thought they would be, cant see the Velcro . . .
    Raleigh NC, OIB NC
    Took this as a reference with a baseball hat for size. Studs look just like they did on all the English cars in the 1950-1960 time frame. Had some Triumphs & Morgans back then. Same studs are also used for roadsters with removable canvas tops.
    If you go with studs be sure they are bolt ins with backing plates or washers. Mine are & its a Whitby cover so I would guess that its standard for them but pays to check wherever you source it.
    When its on you can't see the Velcro.
    Kevin
    MKIV #8234
    Bakersfield, CA
    Nice hat Kevin
    Build thread
    Alliston, Ontario, Canada
    This is a while off for me, but the tonneau and soft top use the same stud pattern correct?
    I imagine you’d have to get the top and tonneau from the same place? Looks like the studs would interfere with the new ffr premium top?
    Raleigh NC, OIB NC
    Nice hat Kevin
    Guilty, also drive them foreign cars. Hat was swag from the BMW Performance Driving school in Greer SC.
    Giggling in the background was my oldest daughter who is competitive & taking the vid. Zinged the old guy when ever he screwed up. I had a better time in this one but took down 14 cones with a spin in another where she had a clean run.
    Kevin
    MKIV #8234
    Raleigh NC, OIB NC
    Quote Originally Posted by Murd View Post
    Live in NC so never considered a top & have no idea about the tops stud layout. FWIW the original English cars used the same pattern for both.
    Kevin
    MKIV #8234
    Jan 2019
    C47105EA-3150-4892-87D0-5A90C7AEB995.jpeg. Jay Leno original Cobra
    Senior Member Hotyacht's Avatar
    Jul 2014
    Auckland, New Zealand
    Quote Originally Posted by Marc 4 View Post
    Just to note that Jay Leno's car is not an original Cobra - it is a hand made aluminium replica with a 427 side oiler engine
    FFR MkIV 8419 - Right Hand Drive
    427W with Inglese 8 Stack injection - 560hp
    TKO600 5 Speed, 8.8 Detroit Trutrak LSD IRS
    VPM Adjustable Sway Bars
    Vintage Wheels 17" Pin Drive
    Jun 2018
    Quote Originally Posted by Hotyacht View Post
    Just a quick note it's not a 427 side-oiler it's a 427 SOHC motor much more exotic and nasty sounding
  21. Likes Hotyacht liked this post
