Results 1 to 2 of 2
Thread: Lines for Remote Reservoir
    Member 3dGuy's Avatar
    San Jose
    Hello, I'm about to mount two of the factory supplied reservoirs onto my fire wall. Since they will be so visible id like to not use the supplied red rubber hoses. im guessing it needs to be about 18" long but i don't know the correct braided line needed. Does anyone know what the right specs are and what to look for to make sure there isn't a problem with the lines and the brake fluid? Thank you.
    My build site : www.ScootinThunder33.com
    Senior Member maczter's Avatar
    Feb 2013
    Xenia, OH
    Brake fluid is non-reactive to braided liners, and this is a non-pressure line, so you can pretty much use anything you desire. I threaded some elbow fittings into the bottoms and used -4 AN hose.
    FFR HR #530
    Race car theme, Tim Whitaker roll bar, Autometer Autolite Gauges, Satin Black, SBC 383/700R4, 8.8 rear with Cobra Brakes, 3.29 gear, Boyd Tank, QA1 springs and shocks,
    My build blog: http://jacks33hotrod.blogspot.com/
