Quote Originally Posted by nuhale View Post
Al, I just looked at mine and it's pretty darn close side to side. I know you've probably looked at the obvious but make sure your ride height didn't settle and still even both sides. I made a little jig with some 2x4 that is 4" and 4.5" (front & rear) and I check here and there for settling.
It can also be the track width as well as camber. When you get over to the guys at Don Hansen's alignment have them take a look at the track width. They do it anyway with thrush angle. I did mine just a bit wider for a nicer fit with the 17" rims I have. Cant recall the exact width but remember 59.5" from tire mount surface. All of that should get it much closer to even.
I'm looking forward to getting to their shop. That will answer a lot of questions for me. I just don't know if that will happen before spring Although, it's pretty nice outside today (and tomorrow, too, I believe) and I plan on getting out with it if I can.
