Results 1 to 11 of 11
Thread: 818C with a Porsche engine????
    Can it be done?
    I'm seriously contemplating this build. However, I'm in the middle of building my 911 race car (which I'll probably never race). So I was wondering if I can use that drivetrain instead of the Subaru? It's an Carrera 3.2L air cooled with 5sp manual trans.
    Also thinking it may be more trouble than it's worth.
    Anything is possible. We have a rotary, VW VR6, 6cyl Subaru, and several electric engine builds. It's a tube-frame chassis so not too difficult to make changes if you can weld and fab metal. I'm personally waiting for someone to do an LS.
    I have no idea how much trouble it would be, and I love my 818s like it was my own child, but it seems a shame to use an engine from an air-cooled Carrera for anything other than a Carrera. I imagine you could get better performance with a much less valuable (and much much cheaper to repair/upgrade) Subaru mill anyway. Just my two cents.
    I've been wondering about the VW VR6 build and how difficult was that? As you can imagine I like German cars.
    Being that I have built 2 race cars, I'm pretty handy with welding and sheetmetal fab. But I'm also looking for an easy build, reinventing all the time can get tiring.
    Armando
    Quote Originally Posted by BuzzSkyline View Post
    You're probably correct. Just building a 911 engine to stock configuration is about $10k.
    San Diego Ca 92106
    Look to post #6 for the dimensions of the engine area.. Hope this helps. I'd love to see a 911 engine in an 818.
    http://thefactoryfiveforum.com/showt...rewall+end+car
    Quote Originally Posted by armandodiaz View Post
    Armando
    http://thefactoryfiveforum.com/showt...r-Build-Thread
    If you are looking for an easy build, I would not suggest anything other than the Subaru engine and transmission designed to fit the 818. Cheap, easy to work on, reliable, and very low center of gravity. Plus they bolt up.
    Fresno, CA
    Can you put the 911 engine in the 818, of course you can with the proper modifications.
    Doug
    Built FFR5196 MKII in 2003, 427w
    Building FFR0058HR, Edlebrock 347-AOD
    San Diego Ca 92106
    There's at least 3 people who are building/have built an 818 using the EZ30 6cyl subaru engine.
    http://thefactoryfiveforum.com/showt...-H6-EZ30R-818S
    http://thefactoryfiveforum.com/showt...hread-H6-power
    I am currently fitting the VR6 in. Should have pix of it in within 2-3 weeks. Fitting the engine is one thing, fitting everything else around that engine is another! I've got VW stuff, VWBaru hybrid stuff, Subaru stuff and 100% custom stuff. It's a headache, you need a plan, a perfect plan. lolll
    How long is the 3.2L air-cooled? I've seen a few Porsche engines and they are all too long by a few inches (measured them myself), which would require most probably cutting the rear FW tubes and doing some magic from there. If you extend the rear end (from suspension and rearwards), which is another option, you end up in need of doing something to the body panels, as they will be too short.
    If it's a race car you are building, probably moding the rear FW tubes is the best option to me. Fit the gas tank elsewhere or smaller and you'll be ok.
    Clovis, Ca
    I would do a air cooled 911 engine in a heartbeat (for an R) after all my stupid issues. It would probably be cheaper than getting the suby motor race ready.
    Way lighter
    No AWIC
    No Radiator
    No need for a drysump
    No need for crazy wiring harness
    PMO carbs are simple to adjust
    I was a dumbarse and sold a spare 911 race motor to buy a "Race Ready" complete Ej25 engine.
    Thanks- Chad
