Thread: Ride height
    Ride height
    On my 818S I have set my ride height 4.5 inches floor to frame as per manual. There is a lot of space between fenders and tops of tires and it looks a little awkward. Should I lower the car and risk contact with driveway crests and speed bumps or leave as is? Are many people going with a lower ride height?
    I think mine is lower than that. I hit on everything. I have even dragged the rear diffuser. I will measure my ride height when I get a chance.
    We originally set the ride height at 4.5 unloaded.
    With 600 lbs of passenger it dropped down to 4". We had issued with tire rubbing fenders and getting the car on and off trailers.
    We went up to 5" unloaded an stiffer springs. All is good now.
    Feb 2013
    Bowling Green OHIO
    I want to get as close to 5" of clearance as I can. I found this for the rears
    "Rear shock spring preload, adjust it before putting it on the car. From the bottom of the spring perch to the bottom of the threaded sleeve is about 3" at ride height. Much easier off the car since you have to put 3/4"ish of preload on spring."
    I set my rears at 3.25" in hopes my ride height is close to 5"
    Are the fronts similar? I would figure it's less because of the lighter load in the front.
    Banned
    My fronts are about 2.75 and I'm sitting around 5.25 ride height. It was around 5.5 in go-cart mode so remember to take into account the weight of everything else you have yet to add (including yourself) and that these springs are not the highest quality and tend to take a bit of a set over time.
    In addition, don't sweat the ride height too much until you have your final wheel/tires installed and air pressures set. You can easily gain or lose a quarter of an inch or more there.
    Feb 2013
    Bowling Green OHIO
    Quote Originally Posted by phil1734 View Post
    Phil,
    Thanks for the info........What are your backs set at?
    Banned
    Rears are around 3.75"
    Senior Member cmcintyre's Avatar
    Danbury, CT
    It shows a front at 2.5, I'm thinking 2.75 for a 5.25 loaded go cart ride height. This if I understand the process correctly!
    " That which is rightly done, however humble, is noble." Sir Henry Royce
    SN 46 In the building 10/4/13.
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
    Feb 2013
    Bowling Green OHIO
    Quote Originally Posted by cmcintyre View Post
    Yes, this is the dimension we are talking about.
