0
0
Originally Posted by
benoit narbonne
Hi can you tell me a little bit how elec. motor with a transmission when you use the clutch
The electric motor will have an adapter plat on it the make the motor look just like a Subaru engine.
Shifting is a little different on and electric system as the electric motor doesn't have to Idle.
to go:
1. Push clutch in.
2 put in first or second gear.
3 Let clutch out. (vehicle doesn't move)
4 Press on the torque pedal and the vehicle accelerates.
5 shift like normal
6 when coming to a stop, you don't have to put the clutch in.
After a day or 2, it will feel very natural.
