4
9
It also took some trial and error to get the right list of parts to connect the Power Steering pump to the Rack so here is my BOM in case it is helpful:
Saginaw P Series Power Steering Pump, 5/8" Keyway Shaft
- Outlet : 5/8-18 in. SAE Inverted Flare
- Inlet: 5/16" Hose Barb
- Saginaw P Series Pressure Reducing Valve - 800 PSI
High Pressure Side hose
- Aeroquip FCM1122 Steel -06AN 90-Degree Hose Fitting
- Aeroquip FCM1103 Steel -06AN Swivel Hose Fitting
- Aeroquip FCC0620 -06AN Teflon Racing Hose
- Breeze 21611 Fitting, 9/16-18 O-ring to 06AN (at rack)
- Breeze 21514 Fitting, 5/8-18 O-ring to 06AN (at pump)
Low Pressure Side hose
- Aeroquip FCC0806 6' Size (8) Teflon Hose
- Aeroquip FCM1104 Steel -08AN Swivel Hose Fitting
- Fragola Performance Systems AN to Inverted Flare Fittings 491949BL (at rack)
- Russell 622270 Chrome -8AN Tube Seal Fuel Hose End (at pump)
