Thanks Thanks:  48
Likes Likes:  504
Page 18 of 23 FirstFirst ... 81617181920 ... LastLast
Results 681 to 720 of 885
Thread: Kit 075 Restart
  1. #681
    remember what I said about coming out of surgery as a hot stripper - see, she's already giving you grief...
    but seriously, if it is assembled properly with good parts I would go with it - unless you are turning Ethyl into a real race car you may be surprised how long she will live
  2. #682
    Ugh that sucks. But you have the expensive rotating assembly, surely its easy/cheap to find a 4 bolt main block? I got mine for $500 and had it tested/machined. You have sunk cost into that block, true, but that parts are where the money's at, right?
    Flatheads surely suck for you.. they look pretty but have comparatively no HP, even when blown. And yours will be covered up anyway.
    Btw, I called a drag racing friend of mine, been racing the same '55 in his family since 59, run a ton of motors through it. 283, 350, 383, blown, etc, and he says as long as you keep below 7000, you can get 500-600 hp out of two bolt mains.
    "Naturally aspirated you can push 500 to 600 hp (which is a ton of hp to make on the street) keeping RPM under 7000 with no problem."
    That is a pretty uplifting assessment. I was already getting around 400 to the crank with the old motor on the flat tappet cam and took it to 6500 regularly. I am hoping that the roller cam and Vortec heads will surprise me. On either the flathead or the Hemi I had an interest in the historical and esthetics. I am about of the opinion to set the redline at 7000 and enjoy it.
  3. Likes shmelty, RoadRacer liked this post
  4. #683
    So the motor is together and will probably be in the car today, hopefully. The shop put a lot attention to detail in the motor. Things like painting the top of the machined area around the intake so all exposed metal is covered and protected from rust. I am really stoked at the quality of work. I think the engine will look good with the polished firewall and polished Hood panel liners.
    engine-16.jpgengine-12.jpgengine-10.jpgEngine-9.jpgengine-8.jpgengine-7.jpgengine-6.jpgengine-5.jpgengine-3.jpgengine-15.jpg
  5. Likes shmelty, JOP33 liked this post
  6. #684
    Yummy, I love me a full roller chevy. Jealous.
    Should have put a loud gear drive in though
  7. #685
    I don't think it is going to spin fast enough to merit one
  8. #686
    Drove up to the shop today to get a firsthand look at how things were going. I had gotten a FAST Dual Synch and for some reason it was not meshing up with the MSD/Holley Sniper combination. I chucked the whole thing and ordered a Hyperspark kit. Maybe next week will see this complete.
    IMG_6184.jpgIMG_6185.jpgIMG_6186.jpgIMG_6187.jpgIMG_6189.jpgIMG_6190.jpgIMG_6197.jpegIMG_6199.jpeg
  9. Likes JOP33, HVACMAN, Mrallsport32 liked this post
  10. #687
    Was a long week. Summit sent the wrong distributor with the hyperspark kit and had to order another. Instead of shipping it from Arlington which would have been at worst two days, they shipped it from Georgia to St. Louis, to DFW, to St. Louis, then back to Tulsa, then over to REady Motorsports. Most excrutiating 5 days of my life. Lesson learned. I could have bought the part in Arlinggton and driven it up, returning the same day. But at any rate, most everything is in. They are checking details, connections and tying up the wiring etc. Should be able to start it Monday.
  11. Likes RoadRacer, JOP33, sread liked this post
  12. #688
    this one's for you WRP
    while you're waiting I got a feeling you'll get a kick out of this
    https://youtu.be/g2Rp-x59uVY
  13. Likes JOP33, AJT '33 liked this post
  14. #689
    Thanks, that was fun
  15. Likes JOP33 liked this post
  16. #690
    First start, relatively uneventful. Thanks to Charles Ready at Ready Motorsports for helping guide me to get this together.
  17. Likes FF33rod, Mrallsport32, HVACMAN liked this post
  18. #691
    Don Ross is building me engine side hood panels with louvers. Don is a well know nostalgia restorer and fabricator. He has restore at least one of Don Garlit's Swamp Rats as well as the Dragster Jim Nichols Crashed in 67 at Indy. He is currentl;y working on a restoration of the Shark Car, a AA/FD car from the early 1960's. My panels will have louvers.
  19. Likes AJT '33, JimLev, HVACMAN liked this post
  20. #692
    Welp she's completed. Some final tuning up and break in/heat cycling. Should have her home by Friday. Really Appreciate Charles Ready at Ready Motorsports for the workhe and his team have done plus the counciling he has provided through the project.
  21. Likes AJT '33, RoadRacer, HVACMAN, JOP33, FF33rod liked this post
  22. #693
    Okay got her home Thursday Unloading her and I hear a thud on the other side of the trailer. rushed around to see what was up and my wife was face down on the concrete sidewalk. Huge pool of blood. after a minute she was coherent and we got her up and in the house. She refused to go to the hospital which made for a long evening. Got her to the Dr's office Friday, aside from some pretty bad bruising and a broken nose she is okay. After 70, falling is a terrifying thing, probably one of the biggest killers. Completely forgot about the car until today. I had an appointment with Don for the final fitment of the hood panels but had to cancel it. The tune wasn't sport on because I rushed the shop to get the car on Thursday. It is a 4 hour drive. Messed with it a bit Friday night and got it idling pretty good, took it out to log some hours. Brand new motor is tight, probably less than 100 miles on it so I am taking it pretty easy. Took it out today and did some tuning logs. Adjusted the mechanical timing which was off pretty badly and have now started the tuning/relearning process. Have a really good tuner coming over Monday night to tweak it.
  23. Likes HVACMAN liked this post
  24. #694
    Gatineau, Quebec, canada
    Oh my God Bill, please pass along our thoughts to your wife, its the scariest thing I have gone through too. Make sure she's OK!!
    Andreas
  25. #695
    Jun 2018
    North Vancouver, BC, Canada
    Bill, our thoughts are with ya regarding your wife! Was it heat? did she trip? Health stuff is perplexing and scary as we get older.
    Gen 1 '33 Hot Rod #1104
  26. #696
    Hey Bill, just saw this - hope everything is ok up there. Let us know how we can help, there's many of us within driving distance..
  27. #697
    Actually wife is doing well. Broke her nose and got some bruises on her arms. All in all a miraculous outcome. She tripped over an expansion joint in the sidewalk. One of those fluke things. Falls get dastardly after age 60. Since she has recovered, I have been able to return to putting the car together. Did some EFI tuning. enjoy the video.
  28. Likes HVACMAN liked this post
  29. #698
    Here is a video of the car riding around
  30. Likes JOP33 liked this post
  31. #699
    Jun 2020
    SoDak
    Sounds nice...Is that a Holley Sniper you're running?
  32. Likes wrp liked this post
  33. #700
    Yessir, a 4150 Stealth
  34. #701
    Jun 2020
    SoDak
    Quote Originally Posted by wrp View Post
    Nice, I put the Holley Sniper & Holley Hyper Spark system on my 70 Challenger...I really like it.
  35. Likes wrp liked this post
  36. #702
    One thing I had not thought much of was the throttle body propensity to got WOT if a return spring breaks. Had that happen in the GTO once and before I could get the key switched off I was at about 130 mph. when I switched the key off, the steering wheel locked, fortunately straight line. When I switched it back on, WOT again. I finally got it straight enough to shut it off in lockdown mode long enough that when I switched the key to on the motor didn't refire and got it stopped. Someone pointed out only one return spring on my Sniper TB. I added a dual throttle return spring setup today.
  37. Likes HVACMAN liked this post
  38. #703
    Ouch, yes double springs forever! One of the most important things to remember on a car.. luckily when I learnt that lesson many years ago it was sitting in my garage, even then it was scary!
  39. Likes wrp liked this post
  40. #704
    Jun 2020
    SoDak
    Yup...two things on a car to get 100% right all the time
    1) Double springs on TB
    2) Well maintained brakes
  41. Likes wrp liked this post
  42. #705
    Out tuning the car yesterday and captured some footage, Enjoy
  43. Likes JOP33, HVACMAN liked this post
  44. #706
    Village Mills, Texas
    That's pretty awesome. Looks like he couldn't catch you until you got out of it.
  45. Likes wrp liked this post
  46. #707
    Actually I was waiting for him to come up beside me, expecting to do a roll. He just nailed it a few yards back and literally flew by initially. You can see/hear his tires barking when he got around me. He passed me at WOT and I was barely into it. I stopped his WOT pull caught and passed him. The look on his face as I drove around him was priceless. I did let off, I never go past the top of third on these things?
  47. Likes HVACMAN liked this post
  48. #708
    So today was a special day. Went down to Don Ross Fabrication so he could do the final measuring on the Louvered Hood Panels. At the end of the day the panels FFR sells would probably be just as good but I would have had to modify and cut them as well. Don has made these panels out of mild steel. I cannot wait to get them painted and installed. Don is a renowned fabricator. He restored several Nostalgia Dragsters including the Scorpion 2 Car which is current in Garlit's Museum as well as the Nichols dragster destroyed in the famous crash while running Prudhomme in the mid 60's at Indy. He has several nostalgia dragsters in the shop right now.
    IMG_6248.jpgIMG_6249.jpgIMG_6250.jpegIMG_6251.jpgIMG_6252.jpegIMG_6253.jpegIMG_6254.jpgIMG_6256.jpegIMG_6258.jpg
  49. Likes JimLev liked this post
  50. #709
    Catching up on the loose ends. I installed a Lokar flexible dipstick in the new motor the other day. fit like a champ.
  51. Likes HVACMAN liked this post
  52. #710
    Keeping everything build related together, I did post this elsewhere. After five years of wrestling with the hood hinges on my Gen 1 I discovered a solution put out by Dan Ruth some time ago. The solution itself is simple. Move the bottom mounting ball on the gas struts down one inch. It is so obvious it is silly but seems to work better than it ever had worked before.
    IMG_6268.jpgIMG_6269.jpgIMG_6270.jpgIMG_6271.jpegIMG_6272.jpgIMG_6273.jpegIMG_6274.jpegIMG_6275.jpegIMG_6276.jpeg
  53. Likes JimLev liked this post
  54. #711
    Put a new set of wire looms on the car. Since going to the center bolt Votec heads the old school SBC looms don't work. Anyone need a set of the old School Ones?
  55. Likes HVACMAN, JOP33 liked this post
  56. #712
    WRP--Can you show me some pics of how you mounted the rubber seal around your doors? I have seen a couple of different ways. Looking for options.
    Thanks Rick
  57. #713
    I am away from my photos, iwill get it to you as soon as is possible
  58. #714
    Spent a lot of time at my Dad's house this summer. One drawback is no Hot Rod to fiddle with. First thing up on return home is a short cruise to get the oil pressure pumped up. This new motor has an amazing thrid gear pull.
  59. Likes j33ptj, JOP33 liked this post
  60. #715
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    What was that car next to you trying to keep up?
  61. #716
    350/370Z car. I rolled into it from the light, about midway through second he nailed it, what you see is stopping his pull and reversing it.
  62. Likes j33ptj, HVACMAN liked this post
  63. #717
    Went to the Garland Texas Bass Pro Car Show today. Got a best of show award from a previous show. Met Warren there.
    IMG_6673.jpegF5997BF3-7766-46A6-9F51-EC3A8B93FC9E_1_105_c.jpegIMG_6657.jpegIMG_6668.jpegIMG_6665.jpgIMG_6653.jpgIMG_6643.jpgIMG_6661.jpgIMG_6658.jpegIMG_6641.jpg
  64. Likes HVACMAN liked this post
  65. #718
    Jun 2020
    SoDak
    How much was the maroon camaro next to you going for? Yours is a sharp looking car.
  66. #719
    He is asking $69,000. I think this is his first time out trying to sell it
  67. #720
    Jun 2020
    SoDak
    Wow..that's like a Barret Jackson price.......
