Thanks Thanks:  48
Likes Likes:  504
Page 11 of 23 FirstFirst ... 91011121321 ... LastLast
Results 401 to 440 of 885
Thread: Kit 075 Restart
  1. #401
    Fabulous pics from 121 Rod & Restoration of everything coming together. I really like the padding on the roll bar and the panels in the trunk
    37054902_1901665773223901_3668104788945403904_n.jpg37102518_1901665789890566_2296456993843445760_n.jpg
  2. #402
    Senior Member JOP33's Avatar
    Haslet, Texas
    Wow Bill, they are doing an amazing job!
  3. #403
    Senior Member dallas_'s Avatar
    Dallas, TX
    Looks good Bill.
    I've seen the 'before'. Guess I need to swing by and check out the 'after'.
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
  4. Thanks wrp thanked for this post
    Likes wrp liked this post
  5. #404
    Senior Member TDSapp's Avatar
    Frisco, TX
    Quote Originally Posted by JOP33 View Post
    I agree... that is an amazing change.
    Bill, what are the tabs on the roll bar for? Is that where you are planning on the 3 point seat belts connecting?
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  6. #405
    Yes on the three point, we have a pin or set of pins in the roll bar I forgot yo picture
  7. #406
    Some of the nice extras include a cover for the roof to body seam to cover up the attachment holes. It is velcro'd works like a charm.
    Also really pleased with the roll bar padding, it zips on and off
  8. #407
    Also happy with the way the console came out
    The trunk was an exceptionally nice accomplishment. I did not take a pic of the false bottom. You can see the pull in one of the photos. I like the panels on the side as well, they cover up the shock access holes.
  9. #408
    Oct 2014
    Vermilion, OH
    What an amazing transformation on the interior. I wouldn't have picked that color, but seeing it in there I think it looks awesome. You're going to have a beautiful car when its done.
    CVOBill
  10. Thanks wrp thanked for this post
    Likes AJT '33, wrp liked this post
  11. #409
    Thanks, other really cool touches are the padding in the floor beneath the pedals.
    IMG_3377.jpgIMG_3394.jpgIMG_3395.jpgIMG_3398.jpgIMG_3384.jpgIMG_3385.jpgIMG_3377.jpgIMG_3386.jpgIMG_3387.jpgIMG_3388.jpg
  12. Likes JimLev liked this post
  13. #410
    Haslet, Texas
    Wow...is all I can say!
    What did you end up using for your audio unit?
  14. #411
    We haven't installed the speakers yet
  15. #412
    Kind of a tradition has been first start videos, this is the 22nd for Ethyl, including the GTO.
  16. Likes JimLev, HVACMAN, FF33rod liked this post
  17. #413
    Placitas, NM
    That sounds as good as it looks!
  18. Thanks wrp thanked for this post
  19. #414
  20. Likes duff33 liked this post
  21. #415
    Jun 2018
    North Vancouver, BC, Canada
    Absolutely gorgeous, you must be so pleased!
  22. Thanks wrp thanked for this post
  23. #416
    Mar 2017
    Tree-men-dous!
  24. Thanks wrp thanked for this post
  25. #417
    Mounting front fenders, color sanding them
  26. Likes AJT '33 liked this post
  27. #418
    Kory is working down the punchlist, nearing completion., front fenders are on and color sanded, needs to finish the mounting hardware, electric windows, and roof to body electrical work for the wiper motor. Also we worked on shining up the grill.
    IMG_3427.jpgIMG_3431.jpgIMG_3432.jpgIMG_3433.jpgIMG_3434.jpgIMG_3435.jpgIMG_3433 copy.jpgIMG_3434 copy.jpgIMG_3435 copy.jpg
  28. Likes TDSapp liked this post
  29. #419
    Gatineau, Quebec, canada
    Looking fantastic, can't wait to get to that stage as well. Any tips or tricks for the wiper wiring and how you snuck it through the hard top down to the body would be appreciated!!! TY!
  30. #420
    Getting down to glamour shots now. Dan's on vacation so I have to wait until he returns to get the window sweep solution he came up with. Once done with that, final adjustment of the windows is all we'll need.
  31. #421
    Probably coming home next weekend. Today I cleaned the undercarriage off and we bled the brakes after replacing the front brake lines. Only things lacking is the custom installation of the window sweeps, wiring the electric windows, weather stripping, and final buffing/paint touch up. I am certainly stoked. Wife insists on pin striping to so we need to work on that as well.
    IMG_3470.jpgIMG_3471.jpgIMG_3472.jpgIMG_3474.jpgIMG_3477.jpgIMG_3478.jpgIMG_3483.jpgIMG_3484.jpgIMG_3479.jpgIMG_3482.jpg
  32. Likes TDSapp, HVACMAN, AJT '33 liked this post
  33. #422
    Mar 2017
    What a great-looking car! BUt the wife's always right.
  34. Likes wrp liked this post
  35. #423
    Mar 2017
    For some reason, nothing happens when I click 'Like this post'.
  36. #424
    Frisco, TX
    Quote Originally Posted by wrp View Post
    Make sure they also replace the missing lug nuts before you drive it home.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  37. #425
    Oct 2014
    Vermilion, OH
    Bill the Hot Rod looks amazing!
    CVOBill
  38. Thanks wrp thanked for this post
  39. #426
    Thanks Bill
  40. #427
    All the emphasis on the body and interior, I was looking at the engine compartment today and it looks pretty good too
  41. #428
    Onalaska, TX
    But... its a chevy in a ford! looks good though.
  42. #429
    Placitas, NM
    Quote Originally Posted by Dodgeman View Post
    Nothing wrong with a SBC, the heartbeat of America.
    SBF are OK too.
  43. Thanks wrp thanked for this post
  44. #430
    Kory likes the Blue Oval. Today they put the music in
  45. #431
    Haslet, Texas
    Bill - Are you doing any sound in your doors or dash as well?
  46. Likes wrp liked this post
  47. #432
    Had not planned on it
  48. #433
  49. #434
    Placitas, NM
    Wires? We don need no stinking wires
    Nice, where'd ya get them?
  50. Likes wrp liked this post
  51. #435
  52. Thanks JimLev thanked for this post
  53. #436
    Mar 2017
    Hey! Who's this Holley person? I thought the car's name was 'Ethyl'!
  54. Likes wrp liked this post
  55. #437
    Village Mills, Texas
    No........ It's a chevy in a Factory Five. Baseball, apple pie, and Chevrolet. It's the American way.
  56. Likes wrp liked this post
  57. #438
    Final touches and adjustments.
  58. Likes HVACMAN liked this post
  59. #439
    Yard Work
  60. #440
    Weatherstripping on the doors. We also had "Daniel the Pinstriper" put the pinstripes on today. He kept it simple, single lines on each side with a tip at the backside. Signed the artwork for me. The Green tape was to aid him as he lined the stripe up. The color matches the interior color.
    IMG_3526.jpgIMG_3527.jpgIMG_3504.jpgIMG_3507.jpgIMG_3510.jpgIMG_3520.jpgIMG_3521.jpgIMG_3524.jpgIMG_3512.jpgIMG_3522.jpg
