Thanks Thanks:  48
Likes Likes:  504
Page 12 of 23 FirstFirst ... 2101112131422 ... LastLast
Results 441 to 480 of 885
Thread: Kit 075 Restart
  1. #441
    Mar 2017
    Oh what a glorious SOUND!
  2. Thanks wrp thanked for this post
    Likes wrp liked this post
  3. #442
    Village Mills, Texas
    I'm looking forward to the new videos Bill.
  4. Thanks wrp thanked for this post
  5. #443
    Shifting gears a bit, I went out to the Summit Racing showroom in Arlington Texas today. I suppose I expected there to be a lot of stuff. What I did not expect was the quality of the layouts. You can view some of the arrangements in the photographs. It was a very enlightening experience. Want to buy a NOS Kit? They have one laid out on a display board with all the accessories. I would recommend anyone planning a build consider visiting one of the Summit Showrooms. Even if you have already begun or completed your build, you can take an idea and follow it through there. The employees don't ask you what the make and model of you car is when you ask them a question. I watched obviously senior technicians explaining to junior personnel the appropriate way to set up internals for NOS. They were at the level of detail for ring gaps. I was just amazed at what I found.
    IMG_3528.jpgIMG_3530.jpgIMG_3533.jpgIMG_3536.jpgIMG_3537.jpgIMG_3538.jpgIMG_3543.jpgIMG_3546.jpgIMG_3547.jpgIMG_3549.jpg
  6. Likes FF33rod liked this post
  7. #444
    The fenders are undercoated. Working the window whiskers and mounting brackets on the front fenders. Weather strip is complete. Some glamour shots
    IMG_0024.jpgIMG_0028.jpgIMG_0029.jpgIMG_0032.jpgIMG_0033.jpgIMG_0034.jpgIMG_0038.jpgIMG_0039.jpgIMG_0044.jpgIMG_0048.jpg
  8. Likes AJT '33 liked this post
  9. #445
    Mar 2017
    Ethyl's really pretty
  10. Thanks wrp thanked for this post
  11. #446
    Thank you Mick. We are just idling right now, should finish her up soon. You need to come over
  12. #447
    May 2016
    North of sacramento Ca.
    WRP did you get the windows to work. i have mine working fairly good butt top is permenit and made door tops with 1/4 aluminum that turned into more work. Butt goes with the other hand worked parts.
  13. Thanks wrp thanked for this post
  14. #448
    We got the windows working, still working on the whisker strips
  15. #449
    This is cool
  16. #450
    Here is a good look at the gas shocks from Tim Whiteaker installed on the trunk.
  17. #451
    Car is essentially finished except for the window track sweepers. they will be in next week. Fenders are done and the Hood is really nicely finished. Weather stripping is mostly done, lacking only the windows.
    IMG_0132.jpgIMG_0133.jpgIMG_0136.jpgIMG_0137.jpgIMG_0138.jpgIMG_0142.jpgIMG_0148.jpgIMG_0161.jpgIMG_0163.jpgIMG_0168.jpg
  18. #452
    Senior Member JOP33's Avatar
    Haslet, Texas
    I like what you did with the seatbelts Bill.
  19. Thanks wrp thanked for this post
  20. #453
    Thanks, wife likes them better too
  21. #454
    Haslet, Texas
    Are you going to make it to Good Guys?
  22. Likes wrp liked this post
  23. #455
    Not sure, I will probably be out there at least one day, with or without the car
  24. #456
    121 Rod & Restoration working on the window seals for the doors. This will be the last thing except for final buffing.
    IMG_0196.jpgIMG_0198.jpgIMG_0206.jpgIMG_0202.jpgIMG_0211.jpgIMG_0211.jpgIMG_0213.jpgIMG_0214.jpgIMG_0215.jpgIMG_0186.jpg
  25. #457
    Jul 2017
    Not quite sure I understand how that is going to work?? Adding a angle piece on the inside of the door cutout, then there is some type of wiper that attaches??
  26. #458
    Two angle pieces one to each side of the slot then the whiskers glued to the vertical run on the angle. We will have more pictures this coming week. We chose the angle iron approach to avoid using rivets in the top. We felt the panel bond running the length of the slot on each side would give us more strength. I personally like the notion of a cap across the entire top of the door, this just seems to be less difficult.
  27. Thanks erlihemi thanked for this post
  28. #459
    Here are some closer to finished pictures.
  29. Likes duff33, erlihemi liked this post
  30. #460
  31. Likes JOP33, erlihemi liked this post
  32. #461
    Dallas, TX
    Looks great Bill.
    Can't believe it's the same car.
    Hey, someone mentioned in another thread you knew about some other local car shows.
    How about some details?
    SL-C, LS3 525, Mendeola SDR5,
  33. #462
    Kellers is picking back up. There is a GTG at Stacy's Furniture on McDermott and 75 on Thursday nights. There is cars and coffee of course, and there is generally a monthly muscle car show at Gazebos over by the Presbyterian Hospital in Plano. There are a number of special events, Goodguys, Autorama, Pontiac Nationals. teal shoot me a pm and let me know what you are interested in
  34. #463
    Placitas, NM
    Never been to Summit, I do buy a lot of part from them including the NOS kit I bought back in 1989 and still have it on my other car. It's gone from a single stage one injector to a 2 stage 10 injector setup.
    Thanks for the pics.
  36. #465
    You ever get over this way we can ride down there together
  37. #466
    We did have to put stops on the window mechanism to keep them from going too far upwards. There are gaps at the front and end of the windows we haven't decided how were are going to close.
  38. #467
    Senior Member TDSapp's Avatar
    Frisco, TX
    Bill,
    Isn't it about time you were able to bring that girl home? They have had her for about 10 months now.
    Tim
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  39. #468
    Kory keeps coming up with good ideas. Too much rain around here to do anything with it. I might just go ahead and LS it.
  40. Likes HVACMAN liked this post
  41. #469
    Fun little piece where I took the sequence of processes over about a 6 month period that displays the different states of the window seals in the process from start to finish
  42. #470
    So stopped by 121 Rod & Restoration today. Kory and Aaron have touched up and rebuffed the final areas. Abel has worked on alignment issues while Kory has touched up the grill. Car is really looking good. We decided not to bring it out of the shop, we are going to add the rest of the HVAC components and finish that effort..
    IMG_0332.jpgIMG_0334.jpgIMG_0335.jpgIMG_0336.jpgIMG_0355.jpgIMG_0352.jpgIMG_0351.jpgIMG_0348.jpgIMG_0346.jpgIMG_0365.jpg
  43. #471
    I have a confession. It may have been me that killed the site a couple of days ago. I figured I would upload all my pictures into an album/Gallery, then try to comment them so people doing searches could hopefully find useful photos. Well I was minding my own business uploading left and right and discovered I had 192,000 photos. The site filters stopped me at 520. I have since reduced them to a degree down to around 430 ish. I hope you new builders will find them useful, there is still a lot not covered. I may take down some of the glamour shots and replace them with things like pulling the engine etc.
  45. Likes erlihemi liked this post
  46. #473
    We are mocking the Air Conditioner and it should be finished soon. Couple more tweaks and its done, for now. Looking back, some of you that have only come in for the last year may not know that at one time I did a lot of work on the car myself. The guys at SNL Performance and 121 Rod & Restoration certainly did their share, especially in areas I could not have been successful. Travis Hooper, Christian Livingston, and Gary Gutierrez also pitched in and made significant contributions. Roy at Leo's upholstery in McKinney hit an absolute home run. Dan Ruth and Tim Whitteaker were always there with advice and very well constructed newly designed parts that turned the corner. Dave and the ladies and gentlemen at Factory Five also made a significant difference. Also got to give credit to all the members of the forum who shared time and knowledge, offered advices, and provided examples. Going through my pictures I found some older shots from the year or so I drove the completed, registered, and licensed Roadster version of this car on the street. I also turned a few wrenches on it to get it together and to keep it going. Three biggest efforts were rebuilding the SBC that lost a lifter early on; removing, repairing, and replacing the Ford 8.8 Rear end, and installing the adjustable 4 link with the double adjustable QA1's.
    IMG_1094.jpgIMG_1097.jpgIMG_1098.jpgNew Engine_1143.jpgNew Engine_1150.jpgNew Engine_1162.jpgIMG_1609.jpgFront Driver View.jpgIMG_1643.jpgIMG_1715.jpg
  47. Likes AJT '33 liked this post
  48. #474
    Haslet, Texas
    Like the hardline look! Nice touch.
  51. Thanks wrp thanked for this post
  52. #477
    Cleaned her up and took some shots today. Needs final buffing, still a few lines to connect and the side panels to go back in.
    IMG_0099_Forum.jpgIMG_0080_Forum.jpgIMG_0093_Forum.jpgIMG_132_Forum.jpgIMG_140_Forum.jpgIMG_138_Forum.jpgIMG_136_Forum.jpgIMG_0123_Forum.jpgIMG_0099_Forum.jpgIMG_0125_Forum.jpg
  53. #478
    This is the ugly side of the HVAC Install. Keep in mind it isn't finished yet, they are still mocking up the lines etc.
    IMG_0054_Forum.jpgIMG_0056_Forum.jpgIMG_0058_Forum.jpgIMG_0060_Forum.jpgIMG_0062_Forum.jpg
  54. #479
  55. Likes JimLev liked this post
  56. #480
    Also installed the front QA-1 Double Adjustable from Innovative Rodding
