Results 1 to 2 of 2
Thread: 33 rear brake setup
    33 rear brake setup
    I am installing the FFR rear brake setup and have found that for the calipers to fit on the rotors that the caliper mounting bracket must be located on the outside of the other installed bracket, not on the inside as per the directions. Any problem with hanging the caliper in this fashion? Also my front upper control arm dust covers don't fit at all. any suggestions? Thanks D. Sullivan
    Jan 2015
    St Catharines Ontario Canada
    What year of Mustang did you get the rear end from?
