6
Upgraded my motor and trans mounts last night with Cusco mounts and its made a significant difference in engine placement and movement. With the oem Mounts the main coolant feed pipe was very close to the frame almost rubbing on it! I could shake the engine left and right with my hands from the transmission mount location!
With the new mounts the whole assembly is rock solid the engine sits up more as well. The OEM mounts seem to let the engine slant down(downward like this--> \) since there is no real front mount. The cuscos seem to be more solid and help hold the wait of the front of the engine evening out so it sites more even(like this --> --). My coolant lines are now further away from the frame and no longer able to come close to rubbing on the frame! yay
The Cusco mounts I'm sure will shake the car a bit more then OEM mounts but still wont be as bad as a solid mount since they still have very very very hard rubber to help a "bit". Since I'm still on block I can't assess the shake just yet.
(Don't worry about the car parts bench you see in the background. Its the post kit car 280z project. The car will need a new paint job so don't worry no nice cars were damaged for this image.)
