0
6
Originally Posted by
UnhipPopano
If we are talking about the same image, that was a temporary piece while he was in go cart mode. There is a section of rubber pipe on the bottom and another behind the filler cap. The two pieces allow the pipe in the middle enough room to move. For more flexibility you leave a longer distance for the rubber. If you use connect the pipe to the tank and the filler, it will not allow any movement. How much distance to leave for the rubber to move is not known and not documented in either the build manuals and the online builds.
So this is what FFR sent me I called and asked them if it was right they said it was.... Once the body is on I will know better but I assume I will need to cut the rubber to fit onto the fender. Since the directions also state cutting the pipe they used to give you.
