Likes Likes:  12
Page 7 of 7 FirstFirst ... 567
Results 241 to 264 of 264
Thread: RR20AC Build Thread
  1. #241
    RR20AC's Avatar
    Puyallup/WA
    Bad news today. One of the first and best Cobra drivers had to shut the doors to the racing school. Hope those instructors can find another place quickly. Here’s a longer version of my time there. https://youtu.be/7bKVHCt7FZ0
    20th Anniversary MK4 Roadster, #8752, 18 of 20, Delivered 12/03/15, 1st Start 01/28/2017, off to paint 4/13/2017, Forte 351w/ Holley EFI, Forte throttle linkage, TKO 600/Forte Hyd. Clutch, UniSteer Electra Steering, RT's turn Signals, many Breeze parts, Paint by the Cobra Colorist. Finished on 10/08/2017. 500 mile inspection on 10/21/2017, 3000 mile inspection on 1/14/19.
  2. #242
    Bonney Lake, Washington
    That’s a shame!
  3. #243
    Grayslake, IL
    Really like you solution for the heater while still having a glove box (post #10). What are the dimensions of the extended box you built? how did you determine where to cut the opening in the firewall? Did you end up needing to build another box around the blower and run a hose to capture fresh air from the cockpit? I am waiting on delivery so some of this may be more clear once I see it in person but trying to organize all my thoughts on enhancements like this. Thanks in advance!
  4. #244
    RR20AC's Avatar
    Puyallup/WA
    I probably would build a box over the blower if I get a top. I feel there is no need with an open cockpit. The box has to be 2.5”s deep and the other dimensions are just enough for the core to fit inside. I got lucky with placement and only needed to groove the corner for the wiper tube to go by.
  5. #245
    Member MechanicalKnowledgeNone's Avatar
    Columbia, SC
    Congrats!
  6. #246
    Senior Member SSNK4US's Avatar
    Bakersfield, CA
    OMG!!! Seriously?? (sorry a little late) that is so sad!!!! I’ve been through a few of his courses and have had the privilege of actually having Bob for an instructor. Total class act...so very sad to hear of it’s closing
    Build thread
  7. #247
    RR20AC's Avatar
    Puyallup/WA
    3000 mile oil change and inspection done. A few added upgrades too. I added some new headlights that have the option of a running light inside and upgraded bulbs. Needed to rework these after installation as the manufacturing oils inside smoked the glass after first on. My oil pan and bell housing have always concerned me also, as they both were about 3/4 of an inch below the frame rails. Trimmed the housing and the 7 1/2 inch Milodon pan is now installed. Fel Pro has a product called SnapUps that made installation easy under the car. Watched several youtube videos on oil pan installs and the engine were all upside down. Not as easy under the car. SnapUps helped hold and line everything up while installing.
    Here's a couple of pictures.
  8. Likes Straversi liked this post
  9. #248
    RR20AC's Avatar
    Puyallup/WA
    Quick test drive today in fantastic weather. Wife even went. I guess the car is ready for summer.
  10. Likes cgundermann, Paul2STL liked this post
  11. #249
    BadAsp427's Avatar
    Summerville, SC
    It looks sooooo good.... I'm so excited to be getting another 20th Anniversary Roadster on the road.... Tell me, what color red is that? Thanks...
    Mk4 20th Anniversary #8690 ( #8 of 20 ) Purchased 8/18/18----Build Started 8/19/18
    First Start 11-1-18
    ---- First GoCart 11-7-18
    BluePrint Engines 347ci / TKO600
    Carb / Heater / Heated Seats / Cruise Control / Drop Trunk & Battery
    Build Thread Click Here Gel Coat Driver 1/12/19 - Hit 1000 Miles 3-23-19
  12. #250
    RR20AC's Avatar
    Puyallup/WA
    Nissan plasma red per da Bat
  13. #251
    Paul2STL's Avatar
    Nov 2012
    Tacoma, WA
    Looking good Jim!
    MKIV #9122 Ordered kit 5/24/17 received kit 8/11/17 MK4 Base kit +,First Start 4/7/18, First Go-Cart 4/22/18, In gelcoat, licensed and driving 8/11/18. Coyote gen2, T-56, 2015 IRS 3.31, 17" Halibrand replicas w/Nitto NT555 G2, Withby Motorcars power brake kit W/Wilwood pedals, 04 Cobra front brakes, 15 Mustang rear brakes with mods, power steering. Paint Jeff Miller Da Bat, Lexus Spectra Blue Mica W/Toyota Silver Sky Metallic strips. Build thread: http://thefactoryfiveforum.com/showt...Paul2STL-Build
  14. #252
    RR20AC's Avatar
    Puyallup/WA
    Waiting for the weather
  15. Likes cgundermann liked this post
  16. #253
    RR20AC's Avatar
    Puyallup/WA
    Weather is getting better. Sunday cruise with a new gopro mount. Getting ready for track day on April 6th. Works well and you can't even see the mount. https://youtu.be/DUPtHN_vhac
  17. Likes WIS89 liked this post
  18. #254
    wareaglescott's Avatar
    That is a pretty cool vantage point! Looking forward to some track day videos.
  19. #255
    Jan 2019
    I got my complete kit plus coyote and tko600 a few weeks ago. I have the 18x9s and 18x11s whats the best tire size?
  20. #256
    RR20AC's Avatar
    Puyallup/WA
    Front 255/35/ZR18
    Rear 315/30/ZR18
    I went with Toyo. Work really well. Soft. Lots of traction. Down side is they say they last about 5000 Miles and are more expensive.
  21. #257
    RR20AC's Avatar
    Puyallup/WA
    Went to a local shop today as a preview to a Hooked on driving event at the Ridge Motor park in Shelton. Racer on Rails. Awesome guys there and glad to help everyone get going in driving fast on the track. Twin brothers that race BMW's. They also are into full blown simulators and practice daily. The sims were very advanced and they have their cars loaded so they control just like on the track. Paul and I drove the cobras up and had a great time as the weather is fabulous right now. My numbers are on my car and I did a complete tech inspection for the track. I'll pull it up there next Saturday but the weather forecast says rain, rain and more rain. Here 's some pics before I loaded it on the trailer. I did do a 360 video but it take time to edit and I'll get it done later. jim
    P.S Also borrowed some Scales from Paul and corner weighted my car. Was very close so didn't have to adjust but the total weight was 2430 lbs empty.
  22. Likes Boydster, Mark Eaton liked this post
  23. #258
    Oct 2018
    Looks like you have a 4 legged furry speed bump in the 5th pic. I bet he'll move when you fire that thing up.
  24. #259
    Looks great! Hope the weather forecast improves!
  25. #260
    RR20AC's Avatar
    Puyallup/WA
    Weather was Rainy. Hooked on driving had a great event though. Instruction was awesome and everyone showed up except one person. I'll do it again. Great way to experience time on the track.
  26. Likes RXBill liked this post
  27. #261
    Bothell, WA
    Pacfic NorthWET Crazy
    Jim,
    With those webbed feet from growing up in the NorthWET, I'll bet you were in your element. I on the other hand was chasing down a screaching sound coming from the bellhousing. Clutch ajustment fixed it. All better now !!
    As soon as I get more time behind the wheel (totally dependent on the weather gods) for some shakedown runs, I will be down to do a little cruising.
    Great picture.
    Bill
  28. Likes RR20AC liked this post
  29. #262
    RR20AC's Avatar
    Puyallup/WA
    Hi Bill, Did a little cruising today. Spring is fantastic here when the weather cooperates. Yards all done and I'm up for a cruise. Just let me know. There is an event coming up end of the month at Pacific Raceways in Kent. It is SOVREN Vintage racing. Would be fun to have a cruise up there with all the cobras to watch Karen Salvaggio run her coupe. Here's a few pics of the weather last weekend and today in the yard....
  30. #263
    Paul2STL's Avatar
    Nov 2012
    Tacoma, WA
    Nice pictures Jim and that FFR sticker on your trailer is pretty cool! Funny thing is I was off today working on the yard, guess I should of sent you a text.
  31. #264
    RR20AC's Avatar
    Puyallup/WA
    Shoot could have been fun, Next time. Can't remember where I got that sticker. Oh yeh. It was from Paul.
Clever Turn Signal
