Jakester I think you will be fine. To make greasing easier I used to separate the pivot from the sleeve so I could spin the pivot around while greasing. That really helped w/ the old steel on steel setup. The delrin doesn't need that for grease dispersion but could be done for easier access to the grease nipple. And separating it this way doesn't affect alignment. Also, w/ the delrin, I suspect greasing will be maybe a once a year deal.
