Forte's Parts Connection
Coyote engine package BIG DISCOUNTS STARTS FOR MARCH!
Hi Guys,
Thank you in advance for your inquiries and business. March 2016 will have a $600 discount off of the $12,455.00 engine/TKO package now $11,855.00.
I now have the 2015 IRS knuckles, hubs & IRS 3.55 selling for $1400.00. If you purchase the Coyote,TKO & IRS I still have for $13,100.00
I've put a Coyote engine package that sells for $12,455.00. Below is the parts list and a few options you might want.
Ford Racing 2015 Mustang Coyote M-6007-M50A engine, Coyote Electronic/computer, harness kit, Coyote engine cover, Coyote alternator kit, Coyote mini starter motor, Ram 26 spline clutch kit, clutch fork & throw out bearing, clutch mounting hardware, Coyote aluminum bellhousing / block plate & bolt kit, Tremec TKO-600 or TKO-500 (machined to fit FFR chassis), Moroso oil pan & pickup.
The above parts are all of the parts to assemble your Coyote engine / TKO package
A few options include:
8.8 rear axle assembly with 3.55 gears & 11.65" brakes $1725.00
IRS 8.8 rearend with 3.55 gears & 28 Spl. Eaton diff. $1745.
NEW Ford Racing 2015 IRS 3.73 rear end & 2015 knuckles & hubs NOW IN STOCK!!!
Stainless Header 4 into 4 merge headers $1275.00 (no more "J-pipes")
NEW PRODUCT: Coyote Stainless Header with Cat now available!!!
K&N air filter & related air inlet parts $176.00
Fuel pressure regulator $119.00
Speedo recall tool $175.00
Walbro 190 LPH in-take fuel pump assembly $190.00
coolant tank & cap $79.00
Synchromesh oil 3 qts $30.00
If any of these parts are of interest I can ship quickly. Please email me for a complete quote.
Mike Forte
40 Pearl Street
Framingham, Mass. 01702
[email protected]
508 875 0016
www.fortesparts.com
http://www.facebook.com/home.php?#!/...?v=info&ref=ts
The Early Ford & FE Tremec were also originals from Mike. The Mustang firewall adjustable quadrant kit also is an original from Mike. His latest developments are external slave clutch release conversions & cable release conversions too.
Tremec Elite Distributor for: T-5, T-56, T-56 Magnum & TKO-500 & TKO-600
TKO-500 & TKO-600 Midshifter, Front shifter, offset Corvette shifter and more...
A REAL SPEED SHOP with parts, price & knowledge....
Est: 1981 selling & building performance parts to build your dream car...
FORD RACING & QUICKTIME DISTRIBUTOR. NEW 5 LUG AXLES & BRAKE KITS & NEW 8.8\" REAREND IN BOTH IRS & FOX AXLE.
