MKIV Power Steering Upgrade
I am half way through my build and the car is rolling with Engine and Trans in. When moving the car the steering is very heavy leading me to consider a power steering option.
My engine is a 2005 Modular 3V 4.6L V8 and I have the power steering pump and pulley already to hand. My question is has anyone done this before and can offer any problems / solutions that would need to be overcome?
I presume the 87-93 power steering rack would be the obvious choice but there seems little clearance for the lower steering shaft if I add the pump to the block. Has anyone done this without modifying the shaft?
Reading the forum it suggests the 2005-2010 reservoir can be easily installed on the right side of the engine but as you may guess, many other questions keep popping in my head.
Always appreciate the help and advice from you guys.
