Thread: Spinners and Knock-offs - L or R
    So. Bay (So. Calif.)
    Which side of the car does the LEFT threaded spinner go on, Left or Right?
    Left hand thread goes on the right hand side and versa visa .
    Bill Lomenick
    Chotis Bill
    Thanks Bill. I was told the opposite, and it just didn't make sense. This make sense since they will tend to tighten under acceleration.
  4. Likes jwd liked this post
    Cape Coral, FL
    Another good way to remember is the spinner should turn towards the back of the car.
    BadAsp427's Avatar
    Greeneville, TN
    Here are the instructions from FF... https://www.factoryfive.com/wp-conte.../02/Wheels.pdf
    Elk Grove, NorCal
    Quote Originally Posted by ILPBFoot View Post
    My dad told me a good phrase to remember; tight as*
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
