AZMP building and fitting body first 33 rodster
well I decided to do the dirty work first. fitting the doors, top, hood and trunk. it is going well and i made some of my own changes with mounting points and bushings (like the doors, hood and trunk). i will be posting picks as i go along. i did find out that the kit for the 3 link don't fit the 2011 mustang 8.8 rear end so i will be making brackets to use part of the kit. just putting the suspension together making sure it fits OK so i can get it chromed or powder coated.
Take your time fitting the panels and remember to make it fit tite you can always remove more when you have the panels on. Good luck.
