Thread: Alternate Seat Belts
    Has anyone used standard seat belts in lieu of the racing harness? My concern is for my disabled wife who would have trouble using them. I'm wondering if the roll bar would make a good enough mount for a standard belt. We won't be racing and I only need to do the right side. Any ideas? Murph
    Senior Member 6t8dart's Avatar
    Apr 2015
    Irving, TX
    Check out julianos, I used them in my dart. I am considering the three point again for the roadster.
    http://www.julianos.com/seat_belts.html
    I never got any good pics of my belts, this is the best I had.
    Ol Skool
    upstate NY
    First verify what your state requires to register. I mounted mine with the five point on the lower points and ran the third point up to the roll bar. Since the roll bar isn't really a legal bar for any class I'm aware of I wasn't concerned . I just used inexpensive black generics from summit. You can buy these in singles to fab it up and get pretty ones later. I'll dig for pics later if you need them. Or maybe I should just post updates on my build...
    Ol Skool
    upstate NY
    doubled up
    Its hard to see black on black but I'm using the same attachment points low behind the seat. A little challenging to get it all stuffed in.
    Thanks for the response and the pics. I can see well enough to get the idea. Tell me about your car, is it finished etc. Murph
    Take a look at Schroth Rallye belts. They are DOT approved with only 4 mounting points and much easier to fasten. I have a set for my type 65 but haven’t gotten to the point of installing them but I have used their racing belts and they are really great.
    https://www.schrothracing.com/tuning/rallye/rallye-4
    Bill Lomenick
    Chotis Bill
    Senior Member kraftee's Avatar
    May 2013
    Gainesville, Florida
    Don't even get me started again about street cars with racing harnesses in them. I was pleased that FFR gave me a credit on the harness delete so that I could go ahead and install 3-point retractable street belts. Since I am not running the "styling" bar (not really sure how good it would be as an actual "rollbar") I mounted my retractors up behind the seats on a simple but robust fabbed bracket. They seem to fit and retract great.
    ERIC
    "If everything seems to be coming your way, you're probably in the wrong lane."
    Quote Originally Posted by kraftee View Post
    ERIC
    Eric
    I agree that the 33 should have a race harness only as an optional upgrade. By the time they sit at FF, then at the buyers home until the car is done the race
    harness is close to it's life cycle date and wouldn't pass tech anyway. At a minimum the harness should not be in the kit but direct shipped only WHEN the builder
    asks for it.
    Nice job on the retractors.
    DB
    It sounds like we both have an aversion to 5 point harnesses on a street car. In my case, my disabled wife would have a fit using them. Regardless, they just are not needed on a street car. Thanks for the pics and info. Retractable belts are just what I need and now I know they can be mounted on the 33. Thanks again. Murph
