2 mysteries I've been chasing around, curious if anybody has any input
1 - anti-freeze leak on the driver's side
If I park the car for 3 weeks and the weather outside is > 32*F, the underside is bone dry.
If I park the car for 3weeks and the weather ouside is < 32*F, I leak about 1/4oz of antifreeze. The leak is on the driver side - I find green droplets on the oil pan and oil filter. Nothing on the passenger side. No matter where I look (waterpump, intake, heads, etc.. etc...) there is no obvious trail anywhere. If I start up the car and let it idle in the cold, no leaks. Pressure test in the cold - no leaks.
The nearest I can figure is that there's some seal that is not happy with the cold weather. It's a moot issue (since it's only if I let it sit for weeks on end in the winter) but a curiosity to me if anybody has experienced something similar to this.
2 - Oil pressure fluctuations
If oil temp < 150* my oil pressure gauge is rock solid when I'm driving and when I'm idling.
If oil temp > 150*, my oil pressure gauge is rock solid when driving, but if I just sit and idle sometimes the needle twitches around, usually between 25psi and 32ish psi (just a rough guess since the area between 25psi and 50psi is not marked on the autometer ultralite gauge)
When the needle is twitching nothing unusual is happening (e.g., bad idle, etc...). Everything is perfectly normal.
It's not an issue with the idle or the cam because sometimes the needle twitches, sometimes it's rock solid and doesn't twitch an inch. Totally random, but when it's twitching there's nothing unusual happening, and nothing I can tie it to (i.e., it doesn't happen right after going WOT, or after a hard break, or anything memorable).
I ~think~ it might be the oil pressure sending unit - oddly I've read a lot of threads where the units are fine when oil temps are cool, but when they warm up the sender stops working. Although mine is working, just twitchy at idle randomly (i.e., sometimes it twitches, sometimes it doesn't).
Next time I change the oil I'll change the sender, but if that doesn't work I'm just wondering if there's any other reasons for a twitchy oil pressure at idle when the oil temp is warm? I would imagine if it's pointing to a failing component (e.g., oil pump) then I would have issues when driving, not just a twitchy gauge needle at idle sometimes?
