0
0
avcs question
i think i know my answer but before i make work for myself i figured it would be worth asking. I have a 06 single avcs motor. 2.5i intake with outfront fuel rails and the spacers to clear the avcs solenoid. apparently it works with stock injectors but not precision turbo injectors as there 3/4 in longer, no problem made spacers. well the drivers side soleniod goes in but cant be located in the stock orientation with out major work. question is does can it sit in there at about 30deg counterclock wise? also thinking about 1000cc injectors are there stock length ones out there dont want to go thru the hassle to modify something to work if my replacement injectors will. thx Sam
