Russ' Garage
Thanks Thanks:  8
Likes Likes:  46
Page 10 of 11 FirstFirst ... 891011 LastLast
Results 361 to 400 of 406
Thread: Toms 33
  1. #361
    May 2016
    North of sacramento Ca.
    I have more parts and need to get to work, but it is soo smoky from the camp fire north of us that it is hard to go outside. I am sad for all the people in the fire it was so fast & hot. We have been in two floods and it takes a long time to get life back together!IMG_8256.JPGIMG_8257.JPGIMG_8260.JPGIMG_8262.JPG
    The heat exchanger will go in trunk, air to water coolers will go under front fenders.
  2. #362
    Ol Skool
    upstate NY
    Nice. Having an ice chest in the trunk will keep those 33" Goodyear's hooked!! Which Garrets did you go with??
  3. #363
    May 2016
    New garrett G25-550, twins. Setting up for 1000 HP if i want to run methanol at some time, but will set for pump gas as this is a driver.
  4. #364
    May 2016
    Takes a lot of work to make custom headers, but one is all most done.IMG_8263.JPGIMG_8264.JPGIMG_8267.JPGIMG_8268.JPGIMG_8269.JPG
  5. Likes FF33rod liked this post
  6. #365
    Ol Skool
    upstate NY
    My shoulder hurts just looking at those pics! The last set I did was quite awhile back. I chamfered the head side of the flange and swaged the tube into the chamfer to weld it and ground it flush. Never cracked or warped.
  7. #366
    I like the framing you did to your running boards no you can stand on them. I was thinking of doing the same thing because if you dont and someone steps on them they will crack. Good Job.
  8. #367
    May 2016
    One side on to make sher things fit. Need to do a little work on other side.IMG_8270.JPGIMG_8271.JPGIMG_8273.JPGIMG_8274.JPG
  9. Thanks wrp thanked for this post
    Likes wrp liked this post
  10. #368
    That is really looking awesome.
  11. #369
    May 2016
    PS header done, had to make it tighter for ac & heater hoses.IMG_8276.JPGIMG_8278.JPG
    Not perfect but i think they will do the job!
    Will not done, need to put in wastegate pipe.
  12. Likes FF33rod liked this post
  13. #370
    May 2016
    Worked on down pipe and was able to make them out of a 180, but did not have the right size pipe to work on wastegate.IMG_8282.JPGIMG_8283.JPG
  14. #371
    Few can probably appreciate the effort you are putting in to this. Constructing your own headers is nothing short of badass. are you going to clock the output/cold side outlet and run it inside the engine compartment or are you going to run it straight to the intake/intercooler?
  15. #372
    May 2016
    It will go down inside fender to air to water cooler then back into front of engine- we will see about how this go's !!
  16. Thanks wrp thanked for this post
  17. #373
    Where will the BOV be? Consider a Leash Boost Controller
  18. #374
    May 2016
    Need to ask tuner about BOV placement, but in piping after tubes come together and be for intake.
    At this time going with standard BOV.
  19. #375
    Just thinking outloud, would be cool to have Turbo reversed so Downpipe is exiting rearward as a side pipe. That would bring the cold side to the front, out of the path of the heat. What you are doing is really exciting.
  20. #376
    May 2016
    I am trying to keep it clean as possible, with full fenders and running boards it is a challenge!! No room and no room. Water to air coolers in side front fenders with heat exchanger and AC condenser
    in the trunk, plus two not yet made fuel tanks under the top tank for more gas (we will not talk mileage) and to have weight lower.
    Putting another 1&5/8 DOM safety tube from front to back of roll cage along seats.
  21. Likes wrp, erlihemi liked this post
  22. #377
    May 2016
    Talked to tuner and BOVs will be at turbos. So will have all the goodes in one place.
  23. Likes wrp liked this post
  24. #378
    May 2016
    Will it takes time to get the wastegate on, one of two done, now for the pipe to exhaustIMG_8287.JPGIMG_8291.JPG.
  25. #379
    Ol Skool
    upstate NY
    Tom, Great packaging work! You may be inspiring some future turbo builds. I've been eyeballing those barrel style water to air intercoolers myself for a different project. You're going to have a fun ride next summer!
  26. #380
    May 2016
    Got wastegate pipes done, not easy to get all three vband joints to line up. Looking on how much to cut out of side panel.IMG_8293.JPGIMG_8300.JPGIMG_8301.JPGIMG_8299.JPG
  27. Likes wrp liked this post
  28. #381
    Really awesome
  29. #382
    May 2016
    Got the turbo oil drain lines made and on, then worked on ruff cutting side panels.IMG_8302.JPGIMG_8303.JPGIMG_8308.JPGIMG_8309.JPG
  30. Thanks wrp thanked for this post
    Likes erlihemi, wrp liked this post
  31. #383
    May 2016
  32. Thanks erlihemi thanked for this post
  33. #384
    May 2016
  34. Likes erlihemi liked this post
  35. #385
    Absolutely awesome
  36. #386
    May 2016
    Made my two to one intake with air straightener. Had to expand the tube (3 1/2 od and 31/2 id air straightener)to fit.IMG_8336.JPGIMG_8337.JPGIMG_8331.JPGIMG_8332.JPGIMG_8338.JPGIMG_8343.JPG
  37. Likes wrp liked this post
  38. #387
    May 2016
    Pipes are almost done, need to build the MAF bracket yet. Then work on exhaust, take it apart and put back together for i hope the last time.IMG_8349.JPGIMG_8350.JPGIMG_8351.JPGIMG_8355.JPGIMG_8360.JPG
  39. #388
    So you are going to run a MAF? Do they have Speed Density Tuning for Fords?
  40. #389
    May 2016
    This is the way my tuner has me set it up, MAF goes within 4 inches of air straightener. will put at 2 inches.
    I am working with [email protected].
  41. #390
    I ran speed density tune, eliminating math, a little more difficult to tune precisely. I did not know if Fords had that option.
  42. #391
    May 2016
    The tuning is over my head. I trust [email protected] AED and went with parts he works with!
    Think i will go with cortex EBC boost controller, like the boost by gear and overall protection.
  43. Likes wrp liked this post
  44. #392
    May 2016
    Lost my camra card so no pics. Have turbo piping done, now under car exhaust and( Race Mufflers) waiting on them . Fixed radiator moved inlet to off center a long time back had some pinholes from using wire welder, now have tig so weld and grind till i got the garbage out. Did some mods to the finder brace to get rid of nuts on inside., Made oil drain on oil filter( filter on top) to take oil to under car, no more oil on everything to change filter! Still don't know how i will finish the grill.
  45. Likes wrp liked this post
  46. #393
    May 2016
    Looking to put air scop or other intake behind doors in front of rear fenders. My heat exchanger and AC condenser are in trunk with fans but need air entrance and some forced air.
    Have not found any that will work, so will maybe make them. Any ideas?
  47. Likes wrp liked this post
  48. #394
    May 2016
    Got moved out of house so they can do the remodel (been there and done that) let others do it. So i can go back to working on car, but my computer is dead, so no pics till new one.
  49. #395
    May 2016
    Built a tube for lower radiator hose DPP_0001.JPGDPP_0001.JPGDPP_0002.JPG Haft to take left shock off and it goes in from bottom, two short hose's
  50. #396
    May 2016
    Had to rework finder brace(had shim in) to get it all good. So got it put together and finders even and ruff fitting of turbo pipes.
    Don't think it will stay together, it has to come all apart!IMG_8376.JPGIMG_8382.JPGIMG_8377.JPG
  51. #397
    Kingsland, TX
    That's going to look awesome!
    -- Mike --
    TxMike64
    TxM Garage
  52. #398
    May 2016
    This is how it will look, needed the room on bottom end of BOV to get put together. may make aluminum band to go around outside of cutout's.IMG_8383.JPGIMG_8384.JPGIMG_8385.JPG
  53. Likes wrp liked this post
  54. #399
    May 2016
    Working on exhaust, three inch round to oval. Will exit in front of rear wheels.IMG_8387.JPGIMG_8389.JPG
    Most of hoses and wires tied down, going from front to back.
  55. Likes wrp liked this post
  56. #400
    May 2016
    This is the 3 inch pipe from flex to muffler on left sideIMG_8390.JPGIMG_8391.JPG
    goes inside frame.
Flat Irons Tuning
