0
0
Front Strut bracket bolts
Manual says to use one front strut bolt and a rear strut bolt in place if the camber bolt. I couldn't find any bolts that were as large as the camber bolt so I bought new OEM rear strut bolts. They're the same size as bts I already had. They all are about 2mm or more smaller diameter than the hole in the knuckle and the strut adapter bracket.
Is this right?
Originally Posted by
Mechie3
Is this right?
Craig,
Same problem.
This is what I used from Bell Metric, They all fit tight.
Bolt, M16X1.5X65 - Hex 10.9
Washer, M16 - Hardened Flat
Nut,M16X1.5 - Class 10 Nylock
Bolt,M14X1.5X60 - Hex 10.9
Washer, M14 - Hardened Flat
Nut,M14X1.5 - Class 10 Nylock
Craig, I had the same issue but I believe my kit had a bigger bolt and nut in the hardware package that wasn't referenced in the instructions. It fit perfectly so that's what I used. Probably the largest nut and bolt in the hardware package.
Thanks Bob. I cut and pasted the complete product names here for anyone that wants to just copy/paste in the search bar.
BH16X1.5X65P - Hex bolt 10.9
NNH16X1.5YLW - Nylock Nut Class 10 Yellow Zinc
WFHV16YLW - Hardened Flat Washer Yellow Zinc
Total was $22.31 for 2 bolts, 2 nuts, and 4 washers.
W machined ours flat and ground out what weld was in the way.
RetroRacing
Did you mean to post this comment here: http://thefactoryfiveforum.com/showt...tting-properly ?
- You may not post replies
- You may not edit your posts
Forum Rules
